You gotta find the right timings yourself :slight_smile: if I can, you can too, getting them on a silver platter won’t enrich you fully.
4 rx570
lower the hashrate but get better power consumption
moving to herominers, i see the avg find time more better than nanopool.
Hi, you should download the MorePowerTool (check YouTube), to apply lower mV settings than the default 793mV. I have the Gigabyte OC and it is running smoothly on 725mV - 1175MHz, Vram @2140MHz fast timing. I am getting ~118MH/s @100W (HWmonitor) .
Really good info in this thread, thank you to everyone who is contributing :slight_smile:
Does anyone know why the Vega series of cards is performing so much better on the Autolykos algo than other cards? Just curious as to why it gets nearly 4X hashrate on Autolykos VS Ethash, whereas others only get around 2X.
It’s about the architecture aka how it handles memory calls, non Vega gpus waste too much bandwidth which each call as they were designed with bigger memory calls in mind.
I don’t know if I’m doing all good…
Using hiveos, woolypooly and nanominer.
1 gtx 1080 ti
Getting around 106.3mh/s.
Is good?
1080tis cap around that level so yeah :slight_smile:
:love_you_gesture:
Thanks for quick answer
GTX 1070
RTX 3060 TI
Very nice numbers! I found that I could get 190 MH/s at 1350 CC @ 850mV & 920 MC @ 850 mV. I was able to push it higher to 1400 CC and got just under 200 MH, but it took putting the core mV to 900 just as you say.
I already battle with power/heat limitations so I will opt for the lower settings, but definitely good info for those that like to run at max hashrate.
Yeah, for me its max hashrate or no hashrate so I gotta go with 200
TeamRedMiner
GPU 0- 580 8gb 72Mh
GPU 1,2,3- Vega 56s samsung memory 207Mh,196Mh, 202Mh
GPU 4- vega 56 hynix memory 185Mh
GPU 5- vega 64 flashed to 56 bios 207Mh
can you share oc settings?
I just wasnt too familiar with it, but after alot of tweaking i managed to get 197 :slight_smile:
nanominer v3.3.5-cuda111 (using hiveos 0.6-203@210526) on herominers pool:
1060 6gb: 44MH, +0 core, +1200mem, 60% power
the calculator in ergoplatform is ok?
with 700 MH/s it marks me 1.5 ERG per day
Anyone able to get the best possible stable performance on 6700xt?
Settings for the reference model I have.
Use MorePowerTool and apply 625mV as the default value. Extend negative power limit to -50%. Restart your PC and apply the settings of the photo. You should be getting 87-88MH/s @80-85W.
Nanominer, RTX 3060 ti, PL60%, Mem +1200, Core-300 = 165mh/s
