What power usage was this please?
doesnt need riser 16x and 8x pci e
Bro what overclocks did you use?
Also, on Windows or HiveOS?
26-28 MH/s GTX 1050 ti
ERGO Hashrates & mining settings
RTX 2070: 75-80 mh/s, 125w
RTX 3070: 170-172 mh/s, 140w
Hey, Thanks for posting the screenshot?
Can u guide did your bios mod the card?
I have the Elpida memory R580 4GB but I am getting only 52 mh max?
Please help if possible share your setting or guide us on what process you have followed?
Thanks
i will help you with vega and 5600 xt
hi, give this a try. //focus 175 mhs//-hynix//
core 1400
vdd 890
mem 935
amdmemtweak --RC 37 --RP 13 --WR 13 --CWL 8 --FAW 12 --RAS 20 --REF 20600 --RFC 244 --RTP 6 --RRDL 3 --RRDS 2 --WTRL 6 --WTRS 4 --RCDRD 23 --RCDWR 12
Envy
Sharing my efficient settings in W10.
NVM the core clocks settings in the tool. What is read by the miner is the effective Core Clock.
6 x RTX 3070 = 1.014 GH/s
Anybody got an oc setting for GTX 1650 4GB GDDR6? Currently getting 28MH/s with stock clocks.
What is the average power consumption of one gpu? At wall if possible.
  • Correction, it’s a Hynix memory.
Hi , I finally got it up to 170
These are my amd memtweaks
amdmemtweak --CL 19 --RC 36 --RP 12 --WR 13 --CWL 6 --FAW 12 --RAS 22 --REF 65535 --RFC 248 --RTP 4 --RRDL 5 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 24 --RCDWR 11
When i was mining eth, if i put rcdrd less than 23, the gpus will crash , i haven’t tried lowering it for ergo. Do you think that amd tweaks for both will be same ?
can you share the mem tweaks for and oc setting for vega 56 ? I also have 2 vega 56
The mem tweaks for these are :amdmemtweak --CL 19 --RC 36 --RP 12 --WR 13 --CWL 6 --FAW 12 --RAS 22 --REF 65535 --RFC 248 --RTP 4 --RRDL 5 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 13 --RCDWR 12
Is this for the 200MH/s or the ~170
I am using nanominer. I have almost double the accepted shares comparing to NB
Zotac 3080 - 210 mhs
EVGA 3080 - 213 mhs
4xEVGA 3060ti - 160 mhs
EVGA 1660 - 41 mhs
I don’t have them overlocked much… keeping things cool and quiet.
Make sure to Update to this particular driver.
