Nanominer 3.2.0 RX 570 4GB core 1300 mem 1850 67 MH/s 109w
Hi guys, just started mining so I’m not expert at all. I’m using srbminer with a 5700xt, I’m getting 62 mh/s, is it ok or could I get better results with other miners like nanominer? Thanks!
Any info on RX6800 and 3060 (non ti)?
Here:
GTX 1650 GDDR6 29mhs (around 45w I guess)
2070 Super: 82mhs (124w)
1660 Super: 48mhs (78w)
Here:
RX 6800 : 117Mh/s (140w)
RX 6900 XT : 117Mh/s (140w)
RX 5700 XT : 85Mh/s (110w)
RADEON VII : 140Mh/s (170w)
RX 550 : 22 Mh/s (40w)
I mine with Nanominer 3.2.2, i find it more stable and can mine 48 h without errors and under 0,2% rejected shares.
with SRBMiner 067 i had about 5% rejected shares, lots of errors and crashes, i think every 2 hours restart.
Any idea how to improve my 5700 XT Hashrate?
With custom bios made for ETH I’m getting 57 MH/s on nanominer and 70-75 on SRB.
What am I doing wrong?
Sapphire Pulse RX 560 - 30 MH/s 22W on nanominer 3.2.2 with custom BIOS.
im using stock bios on a rx5700xt 50th anniversary (sometimes i game, so i will keep is so) with 1350 MHz 870 mv GPU and 1790 Mem, I get about 85-87 Mh/s with 110w (100w in wattman and 110w at the wall). I had other models of rx5700xt with aprox the same behaviour.
regards
Ok so you’re mining on Windows. I have to try it… My HiveOS install only runs Nanominer 3.2.2-Cuda111, not the standard AMD version. If I run it, my 5700XT does barely 57 MH/s. I can only use SRBMiner atm.
Just testing with ubuntu 20, nanominer and some 3090
Problem: just edited settings, but all GPUs only got 230MH/S.
My settings:
wallet=xxx
coin=Ergo
rigName=test
pool1:10250=ergo.herominers.com
email=…
powerLimits=-76
coreClocks=+225
memClocks=+1460
but it seems nanominer ignored this last 3 settings? Perhaps something is wrong?
Started nanominer with sudo!
Running HiveOS.
ASUS RTX 3060 Ti Nanominer 169.7MH Core -200 Mem 2400 Power Limit 120
(3) PowerColor AMD 5700XT SRBMiner 74.4MH Power Limit 90
XFX THICC III 5700 XT SRBMiner 74.56MH Power Limit 120
(2) XFX 5700 XT SRBMiner 74.54MH Power Limit 119
AMD Radeon Vii (under Windows) SRBMiner 157.13MH Core 881 Core Clock 1600 Memory Clock 1000
My 5700 XT does 85 under Windows with Nanominer 3.2.2 and only 57 under HiveOS with the same miner. I have to switch to SRBMiner in HiveOS to get it to 75 MH/s.
Anyone knows why Nanominer performs this bad in Linux? Note: I’m correctly using v. 3.2.2 and not 3.2.2-Cuda11 version.
1080ti - 93mh
HiveOS, core 120, mem 1700. ~190w
Answering my own question, 3060 (non TI): 105Mhs, 125W, very unstable.
Huge hash drops if card used as display output, hoovering around 50Mhs. Optimal settings are hard to find, sometimes just changing ±50mhz on clocks leads to half the performance. Seems like nvidia really screw this one.
Edit: 115Mhs, 122w, +1000 mem -500 gpu clk, 67% power limit (seem to be the point of diminishing returns).
Windows 10, Nanominer 3.2.2 CUDA
RTX 3060 (non TI) - 108MH/s @ 100W
RX 480 4G - 50MH/s @ 80W
HiveOS, Nanominer 3.2.2 CUDA
RX 480 4G - 46MH/s @ 80W (still unable to enter all OC settings as in Win10)
RTX 3060 is very tricky, even a slight change in core/mem clock or power limit may cause unstable performance.
NV Miner 4.0.0 - Windows 10 20H2
GTX 1660
Stock - 43.8 MH/s, 75 W
1700 MHz Core | 4850 MHz Mem | 750mV - 52.8 MH/s, 52 W
Nanominer 3.2.1 - Windows 10 20H2
GTX 1660
Stock - 42.6 MH/s, 72 W
1700 MHz Core | 4850 MHz Mem | 750mV - 53.2 MH/s, 53 W
Nanominer 3.2 Under Windows 10 4x Amd Rx 580 4gb I’m getting 195 Mh/s stable. Standard clocks settings
TeamRedMiner under Win10 and 5*rx480 4GB @ 332 mhs total, over 66mhs per card, 422w power draw. Modded bios, ETH straps, 1250 core, 1950 mem, cards are not undervolted
*Also same rig undervolted gives 293mhs total at 315w power draw which is pretty amazing. Autolykos is most eco friendly algo I know
SRBMiner + R9_380 40,6 MH/s (Bios 380NR1100.ROM, mmpOS)
RIG 6 x R9_380 = 244MH/s and 780W (ATW)
