Saphire Nitro RX 470 8GB 54.93 MH/s 77.00w nanominer
That’s low hashrate. My RX480 4gb are doing 64-66mh/s below 80w.
That’s very low hashrate for vega.
I’ll try another mining software thinking about getting some more RX 580 4GB I recently sold 4 x 4GB cards at an ultra low price when DAG for ETH went over 4GB thinking about buying some more 4GB cards now that I have some use for them. I’ve knocked loads of 4GB back kinda kicking myself now for not buying them up.
Have your RX480 got Samsung or Hynix, Elpida RAM the ones I’m running both have Samsung K4G80325FB RAM
Hynix and elpida. All with bios mod.
I got a few more RX series cards I will test there mostly Saphire Nitro 8GB, Red Dragon 8GB, RX 580 Red Devil 8GB, ASUS Strix RX470 8GB.
Is this in Windows? I’m using Hiveos and in the extra config arguments, I use “memory-tweak”:“6”.
Then
110 core
1720 mem
113 PL
I do not use the Ethpill
My EVGA 1080 hybrid gets 78-82mh/s. My 1070s are locked at 75mh/s. Titan X Pascal’s do 98mh/s. I have a MSI 1080ti that does 112mh/s.
Also, I’m using NBMINER version 38.1
Thanks, I switched to NBMiner version 38.1 in Windows and used the memory tweak 6 argument after installed a required driver I am getting 65 MH/s. I will test the card in HiveOS with the same command arguments and overclock settings and see if I can get anywhere close to 78 - 82 MH/s that’s a really good hash rate.
Those are the same numbers I get with my 3090s. Very nice!
I bought another EVGA 1080 yesterday and got the same hashrate. I turned down the mem because of temps. They both easily break 80mh/s after another +100 MHz mem and +100 core.
Here are some of my settings for autolykos on dif cards. RTX 3080 lhr v2, Vega 64 flashed to 56, rx 570s, and rx 470s. Red cards are on Teamredminer, green on Nbminer.
Hey saunalife
I am curious what your OC for 1070s at 75mh/s is and what you are pulling wattage on them?
I just took this screen now. I just added another 1070 today and now they like to be at 76 mh/s. You will find my settings and pl here (the screen).
They seem to be happy at around 90-95 watts. I have four of them total.
Edit: The fourth 1070, in my other rig does 76.31 mh/s at 85 watts. It’s an old FE blower type card.
dont have enough CFM to cool more than two cards running around 100w each. 150mh/100w is the best hash/watt ratio ive managed to reach
You have low mem clocks on screenshot. Vega 56 should go to 900,some models do more.
