RX 480 4Gb memori (Hynex)
miner: NBminer
pool: herominers
OC: 1135mv, 2000MHz, Mode computer (88W)
BIOS: mod
…68.03Mh/s…
ASUS Strix RX470
HiveOS - nbminer
41MH/s
I have heard that these ASUS cards can be a little slower in hash rate than other RX470/480 due to having a different memory controller.
Anyone got any ASUS Strix RX470 and managed to hash above 50MH/s?
that is awesome. i was thinking about doing that but wasnt sure how to mod the bios. i have only done simple flashes
The new T-Rex 0.24.2 LHR tune is working pretty well, before I was stuck at around 130-134mh/s on LOL 1.33.
Will let it run through the night and see if it’s holds, started at LHR tune 99, it brought itself down to 95
Gigabyte 3060ti aorus elite LHR v2
Core lock 1325 mem 2600 PL 120w
I use minerstats to set up my simple miner,
locked my core to 1575 mhz and set the mem clock to +1500mhz
I avg 203 W but had a spike when i pasted this
Is it card with hynix memory or samsung?
Does anybody know the hashrate for a GTX 660 Ti 3Gb ?
The DAG fits but I’m wandering if this card will be detected by the miner…
I have an RTX 3090. But I can’t OC for performance.
Can you give me the specs you applied with the RTX 3090?
Thanks
i have a sapphire pulse vega 56 that does 152MH at 87 watts
i got another one but it uses more power at 100W
im using hiveos. they both have identical settings and identical vbios
its not a big deal but im just wondering what is causing the power disparity
Hi i’am new to ergo forum just sharing my results, what are your opinion ? By the way i’am from Macedonia
teamredminer v.0.8.6.3
hiveos latest version
power supply ax1200i
Motherboard H81 Pro BTC R2.0 ASRock
770 watts from the wall
Every card are individually down clocked for best power usage.
Hi
I am quite new mining this very interesting coin, but mining since 2017 with same GPU’s and some breaks between.
Just found out that ERGO Mining on iGPU Vega11 is now even profitable with my very high power costs.
Vega11 iGPU of Ryzen 5 2400G: 5.2 -5.5 MH/s @ around 20 Watts (RAM: DDR4@ 3200 14-16-16-16) Nanominer 3.4.2
GTX 1060 3GB T-Rex 54 MH/s @ 60 Watts + 12% CPU (maybe I got an issue with this after some system setting changes)
GTX 1070 T-Rex 80 MH/s @ 75 Watts + 12% CPU (maybe I got an issue with this after some system setting changes)
I haven’t managed yet to get AutolykosV2 working on my GTX 970. I tried different miners. “Not supported” it says. MiniZ is the only working miner for it right now.
Any solutions for high CPU usage in T-rex? 12% per GPU on Ryzen 5 is to much. Isn’t it?
SRBminer + RX580 74-75 mh/s
Whats your over-clocks and what is your driver version and memory type I am using NBMiner and will try SRBMiner and see if it gives me a better hash rate on my RX580 cards.
Core 1300 mhz 950 mv, memory 1850 mhz 800 mv, driver: 20.4.2, elpida memory, 77 W on the driver, the whole system consumes 160 W on the wall. I have one card.
I’m only getting 47.5 MH/s from my Sapphire RX 470/480/570/580 models they mostly have Samsung memory however they are only consuming 70w or less.
You can try bios mod and amdmemtweak, it helped for me.
My 1660s:
Hynix: 62 Mhash
Samsung: 55 Mhash
(No stress)
Rx 550 4gb (biosmod):
Micron baffin: 30 Mhash
Micron: 28 Mhash
P106-90 3gb:
Samsung: 32 Mhash (so low, i know)
Rx 570 4gb (biosmod):
Samsung: 60 Mhash
R9 380 4gb:
Hynix (lolminer v1.42): 39 Mhash (Only 73w Power)
GTX 1050ti 4gb:
22 Mhash (Trash for Ergo, i know)
Rx 560 4gb:
Elpida: 20 Mhash (trash of the trash, no accept biosmod)
Biosmod and HiveOs, if overclock i get up to 71 Mhash on 570, but as i’m in a tropical country (very hot in summer) i don’t stress my gpus.
