i used same oc for rtx 3060 LHR, and its lowering the hastrate drastically
this driver is not recognizing my GPU.
i have RTX 3060 LHR . have to use the 465 version.
and also having issues in getting good hashrate
Settings? Bios mod? Help please
My 580 goes by 68mh 120w. (I wish it was 80w)
Using SAPPHIRE Vega 64 Nitro +
Stock Bios…
With this:
Core Clock, Mhz
1275
Core Voltage, mV
840
Memory Clock, Mhz
960
FAN, %
90
Tweak
amdmemtweak --CL 18 --RC 36 --RP 13 --WR 13 --CWL 7 --FAW 12 --RAS 22 -REF 65000
--RFC 249 --RTP 6 --RRDL 4 --RRDS 3 --WTRL 9 --WTRS 12
The power fluctuates between 315 Watt and 347 Watt, but the hash rate is relatively stable.
3070-ti Strix
3060 Tuf
3070 Strix
I’m using the latest driver and the latest OS. 3070-ti doesn’t load with a much older driver that would almost double the hash rate for 3060 (to about 119 Mh/s).
HiveOS
NB Miner
RTX 3070 (3) 168.5 MH ea. @ 124W; 60% Fan; 45 deg C
GTX 1660 (1) 59.3 MH @ 59W; 60% Fan; 41 deg C
Absolute Core Clock active in HiveOS:
1500 1500 1500 1600 Core
2700 2700 2700 2000 Mem
150 150 150 144 PL
After a fight with the bios of the Vega 56…
After a get a hammer and almost…
Almost…
hit the pc …
Finnaly…
Maybe was the mighty hammer…
Hi friends,
I want to write you the hashrate on hiveos with ERG, pool: nanopool.
RX 460 4Gb modding bios (it’s now a 560): 32.54 Mhs (core: 975, Dpm 5, Vdd: 800, vddci 835, mem: 2050) (Temp: 65°C)
With bios oem: better hashrate max 23,5 Mhs
RX 550 Supphire 4gb Modding bios : 30.32 Mhs (core: 1050, Dpm 5, Vdd: 820, vddci 835, mem: 2050) (Temp: 60°C)
RX 550 Supphire 4gb Standard: 28.23 Mhs (core: 1050, Dpm 5, Vdd: 800, vddci 850, mem: 2050) (Temp: 55°C)
Total Power consumation: about 170W (without pc).
With Pc (that mine monero with CPU): 222W.
with a standard bios I have 75 mhs, with the modding bios and the optimized setting I got 91 mhs.
Hope to help.
Something can also be done with older cards;)
Does anyone know if I can still improve any of these cards? I’m using nbminer on rtx 3070 and nanominer on others
You may try with 1200-1400 on core. It doesn’t help with hashrate but let you save 10-15 W on one card.
Here is screenshot from one of my rigs mining ERG.
I know that RTX3060 can do over 120MHs but power saving is my priority.
on which video card should i try to make this modification?
On 3070. Try value “1200” or “1400” (check what works best for you) instead of “-475”.
Generally on newest version of Hiveos all RTXs works more efficiently with absolute value fo core. And also there is no need to use power limiter.
My 3070s have core set to 1085 and mem to 2500. With these setting they take less than 120W but they mine ETH which is not as much core dependent as ERG. That’s why you should test best core vaue for ERG.
hashrate drops to 165 mhz, to remain stable as it is, I can also use 1550, but consumption remains the same
I have to say that I’m sorry for missinforming you. It helped me a lot with 3070 mining ETH (10W less with similiar hashrate), it helped me with 3060 mining ERG (12 W less) but in case 3070 mining ERG there is no difference.
Sorry once again.
I need to use N 465.31 bcs of RTX 3070Ti, and i am using nbminer v.37.6
This is the best hash i can get, i hope this will help someone bcs lot of people have problem with this new RTX 3060
Using NBMiner with memory tweak-6 I reached roughly 76mh/s per card using 2 GTX 1070s.
Without memory tweak, I reached 63 mh/s at 120watts for reference.
settings:
GTX 1070 (1x8 pin,1x6 pin): +700 memory, -300 core, 50% power (around 100w)
GTX 1070 (1x8 pin only): +700 memory, -100 core, 50% power (around 90w)
I’m pretty sure the 10-watt power difference is due to the additional 6pin connector.
90-100w (95w avg) mining on Ergo compared to 140w on Ethereum is insane.
Ran it for a few hours it’s stable so far.
