Hi, could anyone help me with this rig? I have 4x570 and I’m getting pretty high temperatures and pretty bad power consumption. Is this normal?
Thanks!
Thanks!
Hi! Could anyone tell me if this rig is drawing too much power compared to other 470s. I’ve been searching a lot and the best power draw I could find was on this vid.
https://www.youtube.com/watch?v=rJdnTgAtSM8
Is this even realistic, what is a normal power draw from 470s?
Thanks!
Hi, can you share more details on how you made the flashed vega 64 to run 204MH/s?
I have mine flashed from vega 64 nitro+ to vega 56 nitro+ bios but cant get more than 188Mh/s
The vega pulse is around 204mh/s
The nitro+ vega 64 flashed with bios 56 is around 203mh/s
Vega 64 flashed:
Core 1440
VDD 915
MEM 960
Fan on auto or 70% your choice…
The strap that I use.
amdmemtweak --CL 20 --RC 36 --RP 11 --WR 14 --CWL 8 --FAW 12 --RAS 20 --REF 65535 --RFC 248 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 13 --RCDWR 12
Thanks, I’ll check it out, you use TRM as the miner ?
Yes. I only used TRM for the amd cards
NBMiner + EVGA and Zotac RTX 3060 = 121 MH/s (Overclocked)
Driver and miner version and settings for gpus?
Rig 01 Motherboard TB360-BTC PRO BIOSTAR Group (5.13 05/23/2019)
CPU
6 × Intel(R) Core™ i5-9600K CPU @ 3.70GHz AES
Disk Model
ATA KINGSTON SA400S3 240GB
(10) RTX 3060, Core -200 Memory 2300 PL 105 W 120 MH/s per GPU
Rig 02 Motherboard TB360-BTC PRO BIOSTAR Group (5.13 05/23/2019)
CPU
Disk Model
(9) RTX 3060, Core -200 Memory 2300 PL 105 W, 120 MH/s per GPU
Rig 06 Motherboard TB360-BTC PRO BIOSTAR Group (5.13 05/23/2019)
CPU
Disk Model
(7) RTX 3070, Core -400 Memory 2800 PL 130 W, 173 MH/s per GPU
Driver Nvidia 460.39
Total Hashrate 3.501 GH/s
im very happy
generally around 180-185Mh/s with a decently tickled V64 on water.
1350mhz core effective @ 910mv (although vddc sits at 950 so ignore vcore) 1070 mem @905mv, using the Samsung lucky V64 timings with AMDmemtweaker.
Edit: using TeamRed Miner on hero miners pool.
Try to play with the settings, mine is Samsung ( modded bios ) esl Elpida but try. Must be around 60-70w
For VEGA the best is TRM…
For other AMD the best is lolMiner with less fee than the others and with lot less Watts consume, around 3-5W same OCs. And one of the best average pool Mhs.
Also consider than only TRM and lolMiner are giving the reality of Mhs… any other of the miners lie in the Mhs… because they don’t discount the time it takes the card to make the DATA ERGO Set. They just pause the Mhs… giving unreal and fake information…
This is an ERGO Miners Comparative with 4 x 3080, with Fixed Core Clock to avoid any Silicion Lottery of the GPU.
All 3080 are at:
Core 1500
Memory 900
Miners :
Nbminer : Fee 2%
Nanominer : Fee 2.5%
T-Rex : Fee 2%
lolMiner : Fee 1.5%
Shares:
| Miner | HiveOS | Pool | Stales | Comment |
| Nbminer | 1925 | 1924 | 5 | Shares are reality |
| nanominer | 1900 | 1879 | 7 | Included Fee in the shares |
| T-Rex | 1917 | 1914 | 6 | Shares are reality |
| lolMiner | 1964 | 1969 | 4 | Shares are reality |
core and memory?
Thank u
I can get only 116
I’m still playing with my setup. Actually dropped to 109MH/S overnight so I’ve made the following changes:
coreClocks=-200
memClocks=+500
65 % power 67degC 78% fans
Power draw increased from 119W to 129W
Now I’m hitting an average of 125+ MH/s, just have to watch for 3-6 hours to confirm.
Asus RTX3060TI Dual Mini V2 LHR
Nanominer on Windows 10
System specs:
Asus GPUTweaker OFF (causes interference)
Asus AISuite UNINSTALLED (do NOT run this software for any reason, let alone mining)
Windows Power mode: High performance
MOBO: Optimised defaults with DOCP (XMP) on. RAM is DDDR4 3200Mhz C16
CPU: Ryzen 5600X at defaults, no software control, running off optimised defaults from MOBO
See graph: previous settings were powerLimits=-40 without any core or memory clock settings specified.
Hello LC1975,
I have a question, my Vega 56 Pulse only gets 187.5 Mh/s. But why does your Vega get much more. Can you help me out with that? Or can you tell me your settings :)?
Thanks in advance
