on rx580 what miner and voltage
Gainward RTX 3070Ti core 1515 mem 2700 and pl depend on every card, for me go from 135 to 160w and give me around 174 Mh/s
so just played around with settings down to 160mh but at only 93w with my vega 64 with 56 bios
core down to 1225 and hbm to 950mhz both 800mvs. so lost 10% hash at 30% less power
hello everyone, new one
I bought Vega 56 nitro+ hynix mem gpu. It doesn’t work, it always restarts. what settings will i use? can you help?
gpu 2-4 sapphire vega 56 nitro+ ?
So which belt are you using?
core 1225 vdd 837 mem 847
amdmemtweak --RC 35 --RP 13 --RAS 22 --REF 65500 --RFC 148 --RRDL 4 --RRDS 4 --RCDRD 13 --RCDWR 4
Hynix Memory… Gigabyte Vega 56 hynix
170.1 MH
anther gpu HIS gpu
amdmemtweak --REF 65500
In the case of the Hynix memory version, excessive overclocking is down.
RTX 3080 LHR X8
Friends, someone was able to find the settings for the 3070 lhr? On my settings, I only get 134 mh
nvidia-smi -i 1 -lgc 710
also if anyone could help with 3060 lhr v2 - please, help me). share with me if there are better settings
28 RTX with same OC
1600 | 2400 | 130
Trex: 4450 watts (on the wall and my linky)
lolminer: 4700 watts (on the wall and my linky)
lot less Watts consume, => no no !
thank you for the ergo 3060 lhr settings. I’ve been hunting this down for last few days and yours work like a charm!
The three cards on Autolykos.
RTX 3060 TI LHR Palit OC - NBminer
RTX 3070 Gigabyte Aorus - Trex miner
RTX 3080 TI LHR Gigabyte Gaming - NBminer
How much MHs can you perform with this card?
Hallo , Help me , Ive an RX 570 4 GB an 1 RX 580 8 Gb, Ive only total 90 Mh/s
i have exactly same card, memory on it is quite bad. it doesn’t clock high and doesn’t like low value for --rcdrd. i’m getting ~169mh/s at ~120w, still not bad. try those setting adn you should be good.
core clk: 1212
core voltage: 850
memory clock: 900
soc frequency: 848
tweak: amdmemtweak --CL 20 --RC 36 --RP 11 --WR 14 --CWL 8 --FAW 12 --RAS 22 --REF 65535 --RFC 239 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 26 --RCDWR 12
NVMiner + Tesla K80 30MH/s
– ASUS DUAL RTX3060TI MINI OC V2 LHR --DOP AUGUST 2021–
Nbminer/Trex Windows 10
127.3MH/s
105.5W PL 53%
54c, Hotspot 68c
Fans 75%
gpuClocks=+200 (makes no difference, tried -150 up to +200 too)
memClocks=+765 (crash around +800 and or reject errors)
Hynix memory
Increase PL to 66% or 140watt, no increase in MH/s, temps go up, hotspot to 74c.
Core -200 +200
Thanks, I couldn’t get past 162 with your settings
HI, i have ordered 2 3070 LHR and i’m trying to find info what would be hashrate for ERGO ? RTX3070 Phoenix GS 8GB GDDR6 256 bit 3DP HDMI V1 its gona be around 100 mhs ?
Settings on the 3080?
