Hey buddy,
nice settings. My Vegas 56 only manage 187 mh/s, why do your Vegas manage more than 200 Mh/s. Can you help me out on that?
Thanks in advance :=)
Hey buddy,
Hello…
For the vega nitro + 64
I use this:
Core 1440
VDD 915
MEM 960
Fan (auto)Strap
amdmemtweak --CL 20 --RC 36 --RP 11 --WR 14 --CWL 8 --FAW 12 --RAS 20 --REF 65535 --RFC 248 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 13 --RCDWR 12
For the Pulse 56
I use this:
Core 1450
VDD 915
MEM 960
Fan 70%Strap
amdmemtweak --CL 20 --RC 36 --RP 11 --WR 14 --CWL 8 --FAW 12 --RAS 20 --REF 65535 --RFC 248 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 12 --RCDWR 12
Nothing more… Only this settings…
They are both SAMSUNG memory…
For hynix is more tricky…
Update on RTX3060ti LHR
Over 6 hours.
65% power.
Fans 78%.
66 degrees C.
120.9W
memClocks=+500
coreClocks=-200
Hashrate reported in command line: 122.333 MH/s
6-hour average hashrate: 129.5 MH/s
Now trying 66% power, fans to 88%, and memClocks to +585…
Update on RTX3060Ti ASUS Dual Mini V2 LHR (nanominer, nanopool)
Net profitability:
Still got some tweaking to do…
EDIT
TWEAKED
Same as before but with memClocks=+740
138.1MH/s
[0.528 ERG/day]
So in summary
ASUS DUAL RTX3060TI MINI OC V2 LHR
138.1MH/s
131.7W
65deg C
Fans 78%
gluClocks=-200
memClocks=+740
I am on HiveOS and i get 116 Mh/s core 900, mem 1900.
Can u tell me your real mem clock
Hi! Did you write any miner parameters? Applying same settings but hashrate drops to 60-70.
Asus rog 3060 lhr v2 cards.
Hi! Could you send flight sheet? Are cards lhr v2?
I am using nanominer v.3.3.7-cuda111, every information u have on that image.
Yea cards are LHR V2, first time i get only 116 Mh/s with 900 core and 2700 memory 0 PL and now i try with -625 2700 and i get 140 Mh/s but they drop to 127 and work stable.
And dont forget to set 112PL, i try with more or less but hash drop… so only stable hash is with 112 PL
I can confirm this the hardware and software:
I stress - all ASUS overclocking software is switched OFF.
Before running nanominer, I open GPUTweak to set the fan speeds, nothing else. Then I close it. Do NOT let that software dictate your overclock. Same for AISuite. It’s all complete trash.
If you are running AISuite or similar, uninstall it and reboot with mobo set to optimised defaults, DOCP/XMP on if applicable.
Thanks a lot. I will be test this settings next Week
I hope i gain more mhs and Watt consumtion goss down
zero out the core clock
bump the memory OC to 2650 on the zotac with 107 power
bump the memory to 2550 on the EVGA cards with 110 power
should get you up to 118 on the zotac and 125 on the EVGA cards
some of the EVGA cards can handle 2600 OC on Memory
Got a Zotac 3080 ti Tinity. Can´t seem to mine ergo with it. It games fine but any combination of settings with autolykos ends up with fans spinning full speed for few seconds and then half the hashrate to around 120mhs. Have yet to try other algorithms.
Thank you so much for your OC settings on the RTX3060 v2 LHR
I’ve probably tried over 50 different parameters and never broken over 109 mh/s.
I’m probably not the only miner who cannot sleep at night knowing the GPUs are not running at their max Hashrates
lock the core at 1297 or 1305 from terminal to make it stable
Could anyone share good settings for 3070ti rog strix?
