RX 570 mini 4GB
around 63Mh/s with Mod Bios
at windows 10
1200/1950
Nvidia 3060Ti
Miner: NBMiner
176MH/s
Core: Stock (-100 MHz)
Memory: 8000MHz (+1370MHz)
Power: 120W (PL 59%)
FAN : 75%
Sapphire RX 470 4GB = 63.86MH/s, nanominer, Samsung mem, core: 1200 VDD: 950, mem: 2050 MVDD: 875. card 77w 46°C
Powercolor RX 470 4GB = 60MH/s, SRBminer, Hynix mem, core: 1169 VDD: 950, mem: 2100 MVDD: 900. card 80w 69°C
Hello. Could someone overclock me rtx 3070 on hiveos?
just try this configuration,
mine is RX570 mini sapphire 4GB samsung memory
Show quoted text
Thanks man, I’ll try
what is your Straps ?
what is your power consumtion ?
Nvidia GTX Titan Pascal 12GB, driver 465.89
64.725 MH @ +185 gpu +765 ram 59 C (special copper heat sinks front and back)
170W
i not check it, GPU power around 90w
3060 owners, can you tell me if the gpus need pci 3.0 + 8x + 470.xx driver?
waiting for the same answer too
Hello I’ve got 5 RX470 and 570s mining ergo and with srbminer I noticed it would restart or crash and thought it was too overclocked so I dialed it down a little and it helped but I read something on the actual miner about if it crashes try decreasing the threads but I’m not sure how to do that. But I use overclock settings of 1150 core clock on 470 and 570 and RX470 memory clock of 1950 and the rx570 at 2000 memory. Hope this helped.
Please share config VEGA 64
Omg 1300Gh/s, what gpu are you using DR-Love
Hello, I have an RX 570 card, Power Collor, and I am in doubt about the configuration that I should make of Overclock by the AMD RADEON SOFTWARE software, does anyone have the best settings to help me?
