NBMiner Palit GTX1060 Dual 3GB 50 MH/s
try this, but before that, use modded bios & amd blockchain driver, on amd software change it to Compute mode
received_845040506449381
Am i doing it right?
Or am i in the right place
Mining ERG using rx580 4gb
Modded bios/compute mode
1000mv
1320 core
2100 mem
70mh/s
60c at 95w
My RadeonVII using Teamredminer ~230mh/s
My first day mining with my RX_570_4GB (Elpida) gaming computer on Windows 10.
AMD Software 21.4.1 set to Compute Mode
herominers pool sometimes report Current Hash rate over 50MH/s but SRBMiner-Multi-0-6-5-win64 does not report over 38MH/s ()
whattomine suggests 55.50 Mh/s @ 110W and I can not modify BIOS as this PC is my daily driver.
How to get ideal MH/s of over 50+MH/s with this card?
from where to get modded BIOS for Sapphire RX 570 4 GB BIOS (Pulse)?
Heyo, first time poster. I’m using Herominer with a RTX3090 FTW3 getting between 200 and 250MH/s, averages around 230MH/s. The wub ui bounces me between 350 and 180 MH/S but thats still around 230/240 average I think.
Just using a modified Eth overclock with -500 on the core and +1400 on the memory at around 73% power. Seems to be a sweet spot. Temps sit at 68/70°c on the memory controller with around 60%fan usage, which is easily quiet enough to sleep in the same room. Pulls ~280watts on the card and around 450tops from the wall. But that’s also including all my peripherals. Monitors, lamps, speakers.
@lbzmining please share your amdmemtweak settings and clock settings screen shot on here for Vega 64 :slight_smile:
@pclannet please share you amdmemtweak settings and clocking speed on here please :slight_smile:
I’m using modded bios on my daily driver pc, still play games sometimes, and somehow i got higher fps using modded bios
try this https://youtu.be/fPMSMF30fvg
my highest hashrate is 73
How to standalone solo mine without using pool?
I have Ergo Node Version 4.0.10 synced as on 05-26-2021. should I change ergo.conf with “mining = true” ?
@koesn Hi! What driver are you using? Are you on HiveOS? Windows? Thanks!
I have the same concern. Could you share with us how to tweak GPUs to obtain the about rates? Thank you!
SRBMiner + Sapphire RX 570 4GB (Hynix) = 60 Mh/s | 80 Watts
SRBMiner + Gigabyte RX 570 4GB (Hynix) = 60 Mh/s | 80 Watts
Will you please share your Mod Bios settings for this one. Thanks
I just use Polaris editor u can search at youtube
Someone with any 3080 rtx OC in hiveos?
Thanks for your setting, i got 69 mhs with only 93 watt now, more efficient now
