EIP-0045 x ChainCash: How Native STARK Verification Solves Privacy, Scalability & DeFi Compatibility
Context
While researching synergies between EIP-0045 (native STARK proof verification, see ergoplatform/eips on GitHub) and existing Ergo protocols, I realized the alignment with ChainCash is exceptionally deep - not just a nice-to-have optimization, but arguably the missing cryptographic primitive that solves ChainCash’s three hardest open problems simultaneously.
The ChainCash whitepaper explicitly states: “There is no privacy in ChainCash payments now. This topic is fully left for further research.” This post proposes that STARK proofs are the definitive answer to that open question - and much more.
The Three Problems
ChainCash’s brilliance (fragmenting monetary risk to individuals via trust chains) introduces three architectural challenges:
1. No Privacy
Every note carries its full signature chain - a complete history of who held it. Payment graphs, commercial relationships, and trust networks are fully visible on L1. No business will adopt this at scale.
2. O(N) Verification Cost
Each hop adds ~64 bytes + a Schnorr signature verification (~500-1000 JIT). A note with 100 signatures approaches Ergo’s execution limits. Eventually notes become mathematically unspendable.
3. Non-Fungibility
Each note has unique backing, preventing integration with AMMs, lending pools, and any DeFi primitive requiring homogeneous liquidity.
How STARK Proofs Solve All Three
Privacy via Succinct Proofs & Programmable Compliance
Instead of publishing the full signature chain, the spender generates a STARK proof:
“I possess a valid signature chain of length N”
“Total collateral exceeds X ERG”
“All signatures are valid Schnorr signatures from known reserve holders”
“The chain satisfies the receiver’s acceptance predicate”
The killer feature: Programmable Compliance. A business can require that no signer exists on a blacklist - the receiver publishes the blacklist as a Merkle root, the STARK circuit proves non-membership of all hidden public keys. Mathematical compliance certainty with 100% payment graph privacy.
O(1) Verification via Recursive STARKs
A STARK proof is O(log2 N) in size. Using recursive STARK composition (Plonky2/Plonky3 architectures), each sender recursively verifies the previous proof inside their new proof. A note with 10,000 signatures costs the exact same to verify as one with 10. The scalability ceiling is completely removed.
Because FRI-based recursion is entirely hash-based, this also preserves post-quantum upgradability (more on this below).
DeFi via Quality Pools + ZK Note Splitting
Quality Pools: Notes proven via STARK to meet a quality threshold (e.g., >=150% collateralization, >=3 reputable signers) can be deposited into a STARK-verified pool. The pool mints fungible “quality-wrapped” tokens - bridging heterogeneous trust graphs into fungible DeFi liquidity.
ZK Note Splitting: Alice has a 100 ERG note but owes Bob 20 ERG. She generates a STARK: “I burned a valid 100 ERG note and am minting a 20 ERG note (for Bob) and an 80 ERG note (for myself) that perfectly inherit the same collateral backing.” Making change without diluting trust.
Engineering Reality Checks (Ergo-Specific)
This is where the analysis gets Ergo-native. These aren’t theoretical - they leverage specific eUTXO features.
4KB Box Size Limit - The Checkmate Argument for EIP-0045
Without EIP-0045 (pure ErgoScript verifier): Box ~3,700-4,000 bytes. Headroom: ~100-300 bytes only
With EIP-0045 (native opcode): Box ~1,500 bytes. Headroom: ~2,500 bytes
Without native opcodes, a ChainCash STARK note box is physically full - no room for token data, NFTs, or the encrypted DA payload described below. EIP-0045 is not an optimization - it’s a hard feasibility requirement.
Oracle Staleness via DataInputs
If an acceptance predicate uses a live Oracle (e.g., ERG/USD), the off-chain proof might use a stale price.
Solution: Strict state separation:
Inside STARK (static): proves absolute base units (“backed by 1,500 ERG”)
On-chain (dynamic): ErgoScript uses
DataInputsto check those amounts against the current Oracle
L1 Data Availability via Encrypted Registers
When a STARK hides the signature chain, the receiver still needs the witness data to eventually redeem. If it’s lost, the note is bricked.
Ergo-native solution: EIP-0045 frees ~2,500 bytes in the box. The sender encrypts the witness with the receiver’s public key and stores it in R8. L1 DA with full privacy - no external P2P layer needed. (~33 bytes/hop, ceiling of about 75 hops before fallback to the chaincash-rs P2P server.)
Predicate Registry Boxes
The STARK must prove the note satisfies the receiver’s acceptance predicate, which initially forces an interactive flow.
Fix: Receivers publish their predicate parameters in a persistent L1 Registry Box. The sender reads it via DataInputs, generates the STARK, submits. Ergo’s standard “fire-and-forget” UX restored.
Miner Fee Privacy Leak - Babel Fee Relayers
If Alice pays the L1 miner fee from her known wallet, she links her identity to the “private” transaction.
Fix: Babel-style fee relayers. Users broadcast proofs off-chain; the relayer pays the miner fee and extracts a micro-fee from the ChainCash note itself.
Poseidon vs. Blake2b Hash Mismatch
Blake2b is ~300x more expensive to prove inside a STARK than algebraic alternatives. Required architecture:
Inside STARK: Poseidon (algebraic) - ~300x fewer trace rows
Ergo L1: Blake2b256 - native, can’t change
Bridge: EIP-0045 opcode handles the translation
Implication: EIP-0045 should ideally include native Poseidon support so L1 and ZK circuits speak the same language.
Post-Quantum: Compression Bridge, Not Magic
A common misconception: wrapping a Schnorr signature in a STARK does not make it post-quantum secure - a quantum attacker breaks the private key and forges a valid STARK.
However, EIP-0045 enables true PQ-security. Post-quantum signatures (ML-DSA) are kilobytes per signature and would instantly break the 4KB box limit. STARKs act as a compression bridge: verify massive PQ-signatures off-chain inside the circuit, post only a succinct ~1.2KB proof to L1.
Conclusion
Privacy & Compliance (Critical): Full payment graph privacy + ZK blacklists
Scalability (Critical): O(N) to O(1) via recursive STARKs
DeFi Integration (Important): Quality Pools + ZK note splitting
Post-Quantum (Strategic): Compression bridge for future PQ-sigs
EIP-0045 isn’t just “helpful” for ChainCash - it’s the enabling technology that solves its hardest architectural problems simultaneously. All engineering realities (IVC recursion, Oracle staleness, encrypted DA, Babel fees) are solvable using Ergo’s native eUTXO idioms. Native STARK verification turns ChainCash from an elegant academic prototype into an institutional-grade monetary network.
Architectural Crossroads & Proposed Solutions
To make this a reality, there are a few specific L1 design choices we need to align on. Rather than just pointing out the friction points, here are my proposed architectural paths for the core devs (and @kushti) to critique:
1. The Scope of EIP-0045 (The Hash Mismatch)
The Challenge: Emulating Ergo’s native
Blake2b256inside an arithmetic circuit is prohibitively expensive (~300x more trace rows than algebraic hashes like Poseidon). -
Proposed Solution (The Translation Bridge): We shouldn’t stall EIP-0045 by demanding a native L1 Poseidon opcode (which risks a heavier consensus debate). Instead, the ZK circuit uses Poseidon internally for all IVC recursion steps, keeping the prover ultra-fast. At the very edge of the final circuit, it computes exactly one single Blake2b hash of the final Poseidon state root to output a public variable that Ergo L1 natively understands. One Blake2b hash inside a STARK is perfectly feasible; 10,000 is not.
2. The 75-Hop Data Availability Ceiling in R8
The Challenge: Using
R8for the encrypted witness payload elegantly solves L1 DA, but math dictates a hard ceiling (~2,500 free bytes / ~33 bytes per hop = ~75 hops) before the box is physically full. -
Proposed Solution (ZK Note-Compression Cycles): We shouldn’t rely purely on the off-chain
chaincash-rsP2P server as a fallback, as it compromises true L1 bearer-asset sovereignty. Instead, we introduce a protocol-level “Consolidation Spend”. When a note approaches 70 hops, the spender generates a STARK that validates the entire history, but outputs a fresh “Hop 1” note. The aggregated collateral and trust score carries over cryptographically, but the raw historical public keys are flushed from the active UTXO payload. The old DA is safely archived in Ergo’s immutable block history for off-chain indexers, keeping the active L1 state infinitely self-cleaning.
3. Recursive Proof Bootstrapping (The “Step 0” Problem)
The Challenge: The recursive STARK model (IVC) requires the first spender (the note issuer) to generate a base proof with no prior proof to recurse on. If every reserve contract embeds custom genesis logic, circuit uniformity breaks.
Proposed Solution (The Universal “Proof Zero”): In folding schemes (Nova, Plonky3), circuit topologies must be identical. ChainCash must define a globally standardized “Dummy Base Case” (a mathematically valid Null Proof). Every issuer uses the exact same standard recursive circuit, simply folding their first real signature over this universally accepted Null Proof. This guarantees strict circuit uniformity across the entire network, meaning there is only one master STARK Verifying Key (VK) to deploy and audit for the entire Ergo ecosystem.
