How are computations metered and pricing determined on Celaut?
Each node keeps a record of its clients (other Celaut nodes or external users) and the amount of gas each one has acquired. Gas is an internal unit that represents the node’s resources and has a specific value in ERG depending on the node.
Information Published by Each Node
  • Address of its Ergo wallet
  • Price per unit of gas (in ERG)
  • Amount of gas assigned per unit of resource and time
  • Other data, such as supported architectures
Registration and Gas Acquisition
  • A client registers through an endpoint that provides them with a unique identifier.
  • Then, they request a deposit token.
  • Using that token (added on a Ergo box registry), they perform a transaction on Ergo.
  • The node verifies the transaction, assigns the corresponding gas, and marks the transaction as processed.
Clients are incentivized to adjust their behavior based on the node’s reputation: with low reputation, they make smaller, more frequent transactions; with high reputation, they make fewer, higher-value transactions to reduce Ergo network fees.
Gas Usage and Service Execution
  • With gas available, the client can request the execution of services.
  • Part of the gas is transferred from the client’s gas account to the gas account of the service instance.
  • The node periodically deducts gas from the instance’s gas account based on the resources consumed.
  • If the client does not replenish gas for the service instance, the node will stop it.
  • Endpoints are available to query and manage gas.
Each client is responsible for managing their gas and services separately on each node. However, to simplify this management, more sophisticated mechanisms can be implemented that are less dependent on direct P2P relationships, as mentioned in this thread on the Ergo forum.
Load Balancing Between Nodes
When a node evaluates whether to execute a service instance locally or delegate it to a peer, it compares the gas cost. Since it already acts as a client on its peer nodes and has acquired gas from them through Ergo transactions, it can launch instances where it is more cost-effective.
For example, if a client requests Node-A to execute a service, Node-A can decide to delegate it to Node-B if it proves more efficient. The client is unaware of this delegation. Node-A pays the cost using its own gas (gas-b) on Node-B, and deducts the equivalent from the client’s gas account (gas-a) in its own internal registry.
Prev post
Next post
More info. about payment wallets management nodo/docs/ERGO.md at master · celaut-project/nodo · GitHub
More concepts info. here: GitHub - celaut-project/paradigm: A paradigm for software design and distribution. and docs/tutorials/celaut_basics at master · celaut-project/docs · GitHub
Update (Aug 2026): the gas model above has been replaced by MU (monetary unit)
The design described above shipped as gas: an integer priced by constants (EXECUTION_COST, GAS_PER_ERG, etc.) that lived roughly 56 orders of magnitude apart from real ERG values. In
practice a real charge quantized to 0 nanoERG — no charge the node computed could ever be settled on-chain — and a “gas” price advertised by a peer meant nothing to anyone reading it,
since no rate was ever attached to it.
The new model keeps three things separate that “gas” conflated:
  • MU (monetary unit) — what the node counts in. An integer account unit with no intrinsic value; it exists so balances and prices never touch a float.
  • The contract rate — what one MU is worth. This is a property of the payment contract, not of MU itself: ContractRate.mu_per_unit travels on the wire with every price a peer advertises,
    so any node reading it can convert into money it understands. Ergo is the default and currently the only implemented contract (MU_PER_NANOERG, 1:1 by default), but it isn’t a peg — a
    node can accept several payment contracts at once, or none that overlap with yours.
  • The display unit — what the operator reads/types (erg by default, or raw mu, or a custom fiat unit later). Purely presentational; never changes what’s actually charged.
Prices are now a vector, not one scalar collapsing everything: RAM, vCPU, disk and tunnelled network traffic are each priced independently in MU per resource-second (or per GiB for
traffic), plus flat one-off charges for build / tunnel-open / resize. Contention raises the price of the specific resource that’s scarce, up to a configurable ceiling — a node short on RAM
but rich in disk can finally say so, instead of one blended multiplier covering everything.
The node now checks at startup that its configured prices actually convert to something settleable on-chain (non-zero nanoERG, above Ergo’s minimum box value) and warns if not — the old
model’s real failure mode can’t recur silently.
Full design + rationale: docs/PRICING.md in the nodo repo.
