I’m in Des Moines and I’ve been poking at Ergo-related scripts on top of a couple of AI APIs, mostly for small personal projects. Every time a model version bumps, the pricing and speed details seem to move around, and I only find out after the fact when a bill looks different or a request gets slower. I don’t have a good system for tracking this — right now it’s just occasional manual checks, which isn’t reliable.
There was some chatter online about a newer Claude version being cheaper and faster, but I’m wary of building anything around it until I understand how the pricing actually behaves in practice. My main worry is that a call I think is cheap turns out not to be once token usage scales up.
How do you all keep tabs on API cost changes for the models you use? Do you automate it, set hard caps, or just check periodically? Looking for what’s actually worked for people here.
After poking around a bit more, I found this piece on Claude Fable 5.2: cheaper, faster and harder to test, which touches on the pricing side. It helps a little, but I’m still unsure how token usage actually scales once requests add up, so I’d want hard caps in place before relying on it.
