Let’s say I’m totally crazy
Sounds very interesting, I’m willing to take a chance on one of my GPUs. Can you provide more details?
Sounds very very good. Let’s test. If the card get broken, than shit happens
I have install the Nsight System (the cuda developer pack from NVIDIA). Connect the card with visual studio?
Just bought a eagle 3060 TI as well Hoping @Ovidiu78 will share his wisdom. Not happy with the LHR thing we pay lots of money for our cards. absolute bullshit!! If I pay for it I should be able to use it for whatever I want. Like buying a house but they cement one half closed and say you cant use it FFS
Where I can find the THR?!
CUDA
CUDA Device
Name NVIDIA GeForce RTX 3060
Driver WDDM
DeviceIndex 0
GPU Family GA106-A
RmGpuId 26880
Compute Major 8
Compute Minor 6
MAX_THREADS_PER_BLOCK 1024
MAX_BLOCK_DIM_X 1024
MAX_BLOCK_DIM_Y 1024
MAX_BLOCK_DIM_Z 64
MAX_GRID_DIM_X 2147483647
MAX_GRID_DIM_Y 65535
MAX_GRID_DIM_Z 65535
MAX_SHARED_MEMORY_PER_BLOCK 49152
TOTAL_CONSTANT_MEMORY 65536
WARP_SIZE 32
MAX_PITCH 2147483647
MAX_REGISTERS_PER_BLOCK 65536
CLOCK_RATE 1837000
TEXTURE_ALIGNMENT 512
GPU_OVERLAP 1
MULTIPROCESSOR_COUNT 28
KERNEL_EXEC_TIMEOUT 1
INTEGRATED 0
CAN_MAP_HOST_MEMORY 1
COMPUTE_MODE 0
MAXIMUM_TEXTURE1D_WIDTH 131072
MAXIMUM_TEXTURE2D_WIDTH 131072
MAXIMUM_TEXTURE2D_HEIGHT 65536
MAXIMUM_TEXTURE3D_WIDTH 16384
MAXIMUM_TEXTURE3D_HEIGHT 16384
MAXIMUM_TEXTURE3D_DEPTH 16384
MAXIMUM_TEXTURE2D_LAYERED_WIDTH 32768
MAXIMUM_TEXTURE2D_LAYERED_HEIGHT 32768
MAXIMUM_TEXTURE2D_LAYERED_LAYERS 2048
SURFACE_ALIGNMENT 512
CONCURRENT_KERNELS 1
ECC_ENABLED 0
PCI_BUS_ID 105
PCI_DEVICE_ID 0
TCC_DRIVER 0
MEMORY_CLOCK_RATE 7501000
GLOBAL_MEMORY_BUS_WIDTH 192
L2_CACHE_SIZE 2359296
MAX_THREADS_PER_MULTIPROCESSOR 1536
ASYNC_ENGINE_COUNT 1
UNIFIED_ADDRESSING 1
MAXIMUM_TEXTURE1D_LAYERED_WIDTH 32768
MAXIMUM_TEXTURE1D_LAYERED_LAYERS 2048
CAN_TEX2D_GATHER 1
MAXIMUM_TEXTURE2D_GATHER_WIDTH 32768
MAXIMUM_TEXTURE2D_GATHER_HEIGHT 32768
MAXIMUM_TEXTURE3D_WIDTH_ALTERNATE 8192
MAXIMUM_TEXTURE3D_HEIGHT_ALTERNATE 8192
MAXIMUM_TEXTURE3D_DEPTH_ALTERNATE 32768
PCI_DOMAIN_ID 0
TEXTURE_PITCH_ALIGNMENT 32
MAXIMUM_TEXTURECUBEMAP_WIDTH 32768
MAXIMUM_TEXTURECUBEMAP_LAYERED_WIDTH 32768
MAXIMUM_TEXTURECUBEMAP_LAYERED_LAYERS 2046
MAXIMUM_SURFACE1D_WIDTH 32768
MAXIMUM_SURFACE2D_WIDTH 131072
MAXIMUM_SURFACE2D_HEIGHT 65536
MAXIMUM_SURFACE3D_WIDTH 16384
MAXIMUM_SURFACE3D_HEIGHT 16384
MAXIMUM_SURFACE3D_DEPTH 16384
MAXIMUM_SURFACE1D_LAYERED_WIDTH 32768
MAXIMUM_SURFACE1D_LAYERED_LAYERS 2048
MAXIMUM_SURFACE2D_LAYERED_WIDTH 32768
MAXIMUM_SURFACE2D_LAYERED_HEIGHT 32768
MAXIMUM_SURFACE2D_LAYERED_LAYERS 2048
MAXIMUM_SURFACECUBEMAP_WIDTH 32768
MAXIMUM_SURFACECUBEMAP_LAYERED_WIDTH 32768
MAXIMUM_SURFACECUBEMAP_LAYERED_LAYERS 2046
MAXIMUM_TEXTURE1D_LINEAR_WIDTH 268435456
MAXIMUM_TEXTURE2D_LINEAR_WIDTH 131072
MAXIMUM_TEXTURE2D_LINEAR_HEIGHT 65000
MAXIMUM_TEXTURE2D_LINEAR_PITCH 2097120
MAXIMUM_TEXTURE2D_MIPMAPPED_WIDTH 32768
MAXIMUM_TEXTURE2D_MIPMAPPED_HEIGHT 32768
MAXIMUM_TEXTURE1D_MIPMAPPED_WIDTH 32768
STREAM_PRIORITIES_SUPPORTED 1
GLOBAL_L1_CACHE_SUPPORTED 1
LOCAL_L1_CACHE_SUPPORTED 1
MAX_SHARED_MEMORY_PER_MULTIPROCESSOR 102400
MAX_REGISTERS_PER_MULTIPROCESSOR 65536
MANAGED_MEMORY 1
MULTI_GPU_BOARD 0
MULTI_GPU_BOARD_GROUP_ID 0
HOST_NATIVE_ATOMIC_SUPPORTED 0
SINGLE_TO_DOUBLE_PRECISION_PERF_RATIO 32
PAGEABLE_MEMORY_ACCESS 0
CONCURRENT_MANAGED_ACCESS 0
COMPUTE_PREEMPTION_SUPPORTED 1
CAN_USE_HOST_POINTER_FOR_REGISTERED_MEM 0
CAN_USE_STREAM_MEM_OPS 0
CAN_USE_64_BIT_STREAM_MEM_OPS 0
CAN_USE_STREAM_WAIT_VALUE_NOR 0
COOPERATIVE_LAUNCH 1
COOPERATIVE_MULTI_DEVICE_LAUNCH 0
MAX_SHARED_MEMORY_PER_BLOCK_OPTIN 101376
CAN_FLUSH_REMOTE_WRITES 0
HOST_REGISTER_SUPPORTED 1
PAGEABLE_MEMORY_ACCESS_USES_HOST_PAGE_TABLES 0
DIRECT_MANAGED_MEM_ACCESS_FROM_HOST 0
VIRTUAL_ADDRESS_MANAGEMENT_SUPPORTED 1
HANDLE_TYPE_POSIX_FILE_DESCRIPTOR_SUPPORTED 0
HANDLE_TYPE_WIN32_HANDLE_SUPPORTED 1
HANDLE_TYPE_WIN32_KMT_HANDLE_SUPPORTED 1
MAX_BLOCKS_PER_MULTIPROCESSOR 16
GENERIC_COMPRESSION_SUPPORTED 1
MAX_PERSISTING_L2_CACHE_SIZE 1769472
MAX_ACCESS_POLICY_WINDOW_SIZE 134213632
GPU_DIRECT_RDMA_WITH_CUDA_VMM_SUPPORTED 0
RESERVED_SHARED_MEMORY_PER_BLOCK 1024
SPARSE_CUDA_ARRAY_SUPPORTED 1
MEMORY_POOLS_SUPPORTED 1
GPU_DIRECT_RDMA_SUPPORTED 0
GPU_DIRECT_RDMA_FLUSH_WRITES_OPTIONS 0
GPU_DIRECT_RDMA_WRITES_ORDERING 0
MEMPOOL_SUPPORTED_HANDLE_TYPES 0
DISPLAY_NAME NVIDIA GeForce RTX 3060
COMPUTE_CAPABILITY_MAJOR 8
COMPUTE_CAPABILITY_MINOR 6
TOTAL_MEMORY 12884901888
RAM_TYPE 17
RAM_LOCATION 1
GPU_PCI_DEVICE_ID 620957918
GPU_PCI_SUB_SYSTEM_ID 354554078
GPU_PCI_REVISION_ID 161
GPU_PCI_EXT_DEVICE_ID 9475
GPU_PCI_EXT_GEN 2
GPU_PCI_EXT_GPU_GEN 3
GPU_PCI_EXT_GPU_LINK_RATE 8000
GPU_PCI_EXT_GPU_LINK_WIDTH 16
GPU_PCI_EXT_DOWNSTREAM_LINK_RATE 8000
GPU_PCI_EXT_DOWNSTREAM_LINK_WIDTH 16
OpenCL
Platform
Profile FULL_PROFILE
Version OpenCL 3.0 CUDA 11.4.94
Name NVIDIA CUDA
Vendor NVIDIA Corporation
Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_device_uuid cl_khr_pci_bus_info
Device
CL_DEVICE_ADDRESS_BITS 64
CL_DEVICE_AVAILABLE True
CL_DEVICE_COMPILER_AVAILABLE True
CL_DEVICE_DOUBLE_FP_CONFIG
CL_FP_DENORM True
CL_FP_INF_NAN True
CL_FP_DENORM True
CL_FP_ROUND_TO_NEAREST True
CL_FP_ROUND_TO_ZERO True
CL_FP_FMA True
CL_DEVICE_ENDIAN_LITTLE True
CL_DEVICE_ERROR_CORRECTION_SUPPORT False
CL_DEVICE_EXECUTION_CAPABILITIES
CL_EXEC_KERNEL True
CL_EXEC_NATIVE_KERNEL False
CL_DEVICE_EXTENSIONS cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_device_uuid cl_khr_pci_bus_info
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE 802816
CL_DEVICE_GLOBAL_MEM_CACHE_TYPE RW
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE 128
CL_DEVICE_GLOBAL_MEM_SIZE 12884901888
CL_DEVICE_HALF_FP_CONFIG Information not available
CL_DEVICE_HOST_UNIFIED_MEMORY False
CL_DEVICE_IMAGE_SUPPORT True
CL_DEVICE_IMAGE2D_MAX_HEIGHT 32768
CL_DEVICE_IMAGE2D_MAX_WIDTH 32768
CL_DEVICE_IMAGE3D_MAX_DEPTH 16384
CL_DEVICE_IMAGE3D_MAX_HEIGHT 16384
CL_DEVICE_IMAGE3D_MAX_WIDTH 16384
CL_DEVICE_LOCAL_MEM_SIZE 49152
CL_DEVICE_LOCAL_MEM_TYPE Local
CL_DEVICE_MAX_CLOCK_FREQUENCY 1837
CL_DEVICE_MAX_COMPUTE_UNITS 28
CL_DEVICE_MAX_CONSTANT_ARGS 9
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE 65536
CL_DEVICE_MAX_MEM_ALLOC_SIZE 3221225472
CL_DEVICE_MAX_PARAMETER_SIZE 4352
CL_DEVICE_MAX_READ_IMAGE_ARGS 256
CL_DEVICE_MAX_SAMPLERS 32
CL_DEVICE_MAX_WORK_GROUP_SIZE 1024
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS 3
CL_DEVICE_MAX_WORK_ITEM_SIZES
0 1024
1 1024
2 64
CL_DEVICE_MAX_WRITE_IMAGE_ARGS 32
CL_DEVICE_MEM_BASE_ADDR_ALIGN 4096
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE 128
CL_DEVICE_NAME NVIDIA GeForce RTX 3060
CL_DEVICE_NATIVE_VECTOR_WIDTH_CHAR 1
CL_DEVICE_NATIVE_VECTOR_WIDTH_SHORT 1
CL_DEVICE_NATIVE_VECTOR_WIDTH_INT 1
CL_DEVICE_NATIVE_VECTOR_WIDTH_LONG 1
CL_DEVICE_NATIVE_VECTOR_WIDTH_FLOAT 1
CL_DEVICE_NATIVE_VECTOR_WIDTH_DOUBLE 1
CL_DEVICE_NATIVE_VECTOR_WIDTH_HALF 0
CL_DEVICE_OPENCL_C_VERSION OpenCL C 1.2
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_HALF 0
CL_DEVICE_PROFILE FULL_PROFILE
CL_DEVICE_PROFILING_TIMER_RESOLUTION 1000
CL_DEVICE_QUEUE_PROPERTIES
CL_QUEUE_OUT_OF_ORDER_EXEC_MODE_ENABLE True
CL_QUEUE_PROFILING_ENABLE True
CL_DEVICE_SINGLE_FP_CONFIG
CL_FP_DENORM True
CL_FP_INF_NAN True
CL_FP_DENORM True
CL_FP_FMA True
CL_DEVICE_TYPE
CL_DEVICE_TYPE_DEFAULT False
CL_DEVICE_TYPE_CPU False
CL_DEVICE_TYPE_GPU True
CL_DEVICE_TYPE_ACCELERATOR False
CL_DEVICE_VENDOR NVIDIA Corporation
CL_DEVICE_VENDOR_ID 4318
CL_DEVICE_VERSION OpenCL 3.0 CUDA
CL_DRIVER_VERSION 471.41
Name NVIDIA CUDA
Gordon you are very close, you still need to do some things before you reach that step. I will make a tutorial on a private link and share it for few hours here.
But well done Gordon again.
Nbminer v39.2 just been released.
Says * fix : ergo more robust protocol handle.
Have to give this a go
Nice… about time will you post results here
I just asked nbminer dev. They say lhr fix for ergo not in this release, hopefully in next one
Keen to learn more also
Same step than Gordon here, stuck at the same place for now. I don’t know if I would go to the end, but if you write a tutorial I would be happy to read it.
Also looking for a way to get the full potential of my 3060ti.
The 3070 is a good old v1 not LHR. Wish I could have bought more…
Here are my settings in case this can help someone and until @Ovidiu78 releases his little how to. Question, your trick works on windows of linux only ? or both ?
I assume you can setup the GPUs on windows and then just use it on both windows and linux
I would assume the same. Just asking as I would then need to build a windows system to perform that.
Really curious about that path.
Also waiting in anticipation. It will be a game changer.
I’m calling it now, Ovidiu is trolling. I’ll turn my rig off for a day if I’m wrong
I fear the same, unfortunately.
No problem, then I’ll send the 3060 LHR back and get the 3060TI LHR for it.
hello friend, which driver do you use? and what operating system? Thank you
Here you can have a solution:
We found some of the 3060/3060ti/3070 makes Waves in ERGO, some not and some yes. Why is not yet founded. So they don’t have a fix mining… We are not talking about the Up and Down for the Dataset.
We found that the result of this cards is around 85-90Mhs.
There is a configuration that will increase that Mhs in around 25% with lolMiner:
For the 3060 is:
Core 1185
Memory 1700
PL 150
That will give 101Mhs in lolMiner. For that LHR Card the best miner is lolMiner. We will show a comparative now
For the 3060TI/3070:
Core 750
Memory 1700
PL 150
That config will give 113Mhs with lolMiner nearly 4% extra than Nanominer with 108 Mhs
That will give 108 Mhs in Nanominer
