No news for THR parameter?
I’m doing 129 mh/z with NBMiner, with the following settings:
RTX 3070: -600 / 1900 / 106.
The biggest problem for boys who mine today is not the limitation of the LHR, but the laziness to look for more effective solutions investing their time.
I didnt get further than this. @Ovidiu78 master troll or master software engineer?
Nice story bro.
I have 10 MSI ventus that easily do 130+ and two GB Eagle that are just not possible to get over 95Mhs.
Tried ALL different settings. Looks like I should send them to you instead of returning them.
try core +0, mem + 1000 , PL 65% , 63%
Same here, on new MSI Gaming Z Trio, rises to 95MH/s then drops to 85MH/s, no matter what settings. Really strange since 3070 ti LHR mines nicely over 170MH/s
Okay so after some playing around…long hours I was able to get my 3060TI Eagle OC Gigabyte card (LHR) up to 137.2 MH/s.
NB Miner on HiveOS. I noticed a 1 watt difference between NB miner and HiveOS. So you need to set your power on HiveOs to 121 to lock NB miner at 120. Make sure its the latest Nvidia driver on HiveOS. (Beta driver)
You can now decrease your clock slowly till you find your sweet spot
Also you need to wait for the miner to settle let it find at least 5 shares before you make further changes.
Hope it helps I will experiment some more
Do you use 470.63.01 driver ?
i’m stuck at 129Mh/s with a zotac twi edge 3060 ti OC LHR
N 470.63.01 yip. Does yours have Samsung mem?
Nop I have hynix, with new driver it seem to be better, let me some time to opti
Use these settings for your cards and use t-rex miner the latest one.
Core 990, mem 2600, power 130, fans 90% temp limit 48.
Let me know how that works
Gah no wayback machine to see if you posted a link or not
Not bad… lot more Memory and 23W for
113Mhs / 98W = 1.15Mhs x Watt (could be more with your memory)
131 Mhs / 120W= 1.09 Mhs x Watt
Also considering that T-Rex inflates Hash and give less in Average at pool … in terms of effiency lot better my solution
But nice to see you with the 130Mhs. I’m able to with another config at only 110W and real hash
-I have an EVGA GeForce RTX 3060 Ti FTW3 LHR and I can’t get 80mh.
-On the rvn it works quite well. I have a friend of mine who also bought the same board and he has the same problem
Me too, I still tuning not stable
Sometimes it drops to 80-90 MH/s and core rise up to 1100+
My current setting 132 MH/s core/mem 864/8000 power 107W nbminer39.2 470.11
Have you try the new lolminer 1.32?
semi unlock with –mode LHR2 parameter !
I try with my 3070ti and 3060ti but same hashrate as 1.31 version …
