Hi , ive got the Palit 3060 TI LHR , clock 0 , mclock +995 , PSU 54% , FAN 70% , 107w 1.25mh/w @ 132mh/s
I have about 95mh\s with this setup. 2minners, trex
Is there anybody who has the same estimated raward as it is in whattomine?
I recently read what seemed at first to be a crazy suggestion, but after trying it, I was rather surprised at the result. Firstly, make sure a 3060 Ti is in the x16 slot with a monitor attached. Download and run a small game (full screen) which has minimal impact on the GPU itself. I used a small Tower defense game from the MS app store. While the game is running, start your miner. (I’m using NBminer). My LHR card gets me within 95% of a non-LHR card. Worked on my non-Ti 3060 as well - 109Mh vs expected 115. Ti card gives me 160 Mh…
After making these wonderful oc settings, my mh values increased.
Thank you very much for your sharing
The inno3d 3060ti gives 132.9 mh fixed mh, but the MSI branded 3060ti starts with 132 and then goes back and forth between 125-128, do you have any idea about it?
seen ive posted alerady
It will go up and down , thats normal , during the day you will see it goes higher than 132 and sometimes lower
Gorim , checkout for your specific card online , try miningchamber and then adjust slowly
I have the same exact card along with the Zotac 3060ti Amp White Edition. Both are LHR of course. They both react the same upon beefing up my OC settings. They somehow crash and reset back to default value no matter the saved profile you have on MSI Afterburner.
Try the following OC settings, hopefully they might help:
PL: 54 (Twin Edge OC), 50 (AMP White)
CC: -100
MC: 900-1000 (usually they crash at 1000 or higher)
Fan: 80%
Temp: 50-55 celsius
MH/s: 134 expected @109W (Twin Edge OC) , 134 @119W (AMP White)
Good luck
Was stuck on 116.5 MH/s with my PNY 3060ti LHR
Recently tried NBminer 39.5 with ergo unlock feature and saw marked improvmenet:
seetings below
Nice, can you share your lhr parameter for nbminer please?
Sure, was -lhr 85
Tho when inputing into miner config for nbminer must use parentheses like other arguments
So its:
“-lhr”: “85”
Something like that, check suggestion on the info button to be sure.
Thank you, it didn’t work with mine, it’s probably an hynnix issue wih my card…
Ah yeh that sucks. I think it says in the release notes for the build that it does not work well with hynix memory.
Thanks for this!
I have two 3060s and a 3060ti in the middle (all Samsung)
I added a space then this code to the end of “Miner Options”:
-lhr 99,85,99
And it works great!!
Nice one.
Good to see the devs making progress with the lhr unlock, with decent power efficiency too.
Looking forward to further developments.
I have my MSI 3060ti LHR Ventus 2 Fans
And I got a Hashrate of 132 Mhs on ERGO with 70 PL +100 CC +1000 MC 135W
Man, 3060 ti lhr XLR8 here,
Finally got some stable 131 Mh on t-rex, mine seems to kick in lhr above +1000mhz memory clock, so that’s not an option
Had to fix core clock on MSI afterburner, just setting an OC didn’t work, you can do that using curve editor, shift selecting the entire curve, drag a point and hit shifh+enter and type the fixed value, i’ve used 1020mhz
Memory: +920
PL: 62
131mh/s @ 120w
