MSI RTX 3060 Ti Gaming X LHR stable on that 2700 memory clock?
HiveOS MSI RTX 3060 Ti Gaming X LHR stable on PL 120 CC 140 MC 2700 (if u used Windows 1650)
I have the same card can t even get to +950. it keeps crashing.
My 3060ti is ASUS Dual GeForce RTX 3060 Ti 8GB:
With the proper OC I can get around 136-137 MH/s stably
Stable with 23 shares⌠
Youâre a god thanks
This is strange. I was looking to improve the rate for my Hynix card better than 120mh I adjusted it to -200/2500/120 and my one Samsung and the Hynix dropped to low 80s. I changed the Hynix it back to -900/2000/120 just like both Samsungs were set. The Hynix card returned to 120mh but the Samsung stayed in the 80s. I hadnât changed the Samsung but it adjusted and now nothing I do will bring it back to 130+ that it has been at for days. Any ideas?
I also had a lot of issues combining them on one rig. I cant even get the Samsungs to boot on Minerstat, works on Hiveos.
For now I guess its better to seperate them if you canâŚ
The hash rate for this one Samsung is unstable. It goes up to 135 and crashes down to 78. Any ideas how I can reign this in to stabilize around 130. Not sure which variable to start changing first, Core, Mem or Power, any suggestions?
Set Core to -950. If that doesnât help, itâs -1000. For me, depending on the card, core between -900 and -1000 works stably.
Try to test with absolute value for core like 1350 for me
How you do absolute in hiveos?
You nailed it! Iâve been steady for over 10 hours now. Small changes fixed it. Before I would drastically change all the settings and it would stay in the 80s. I was able to dial it in by making tiny adjustments and waiting. Thanks again.
Personally I wonât use my 3060 ti LHR on ergo
On RVN you can get around 30mh, which works out to about $3 a day after power
On ERG, 140mh at 100w would get you $2.80 after power (and you canât get that on an LHR)
You would have to get 150mh at 100w to equal the return.
Iâm not a huge fan of RVN, but rather than loosing .20 - .30 cents a day per card, Iâll just mine whatâs more profitable, and trade.
The regular 3060s are much closer to the non LHR, I can get 118 which with the lower power and less heat is worth it to me.
Different with HYRIX and Samsung , one is 1350MHZ and 900-1100 , SAMSUNG ,need near by 900MHZ , - core or ,lower power.
Any results on Palit RTX 3060 ti?
You have very high memory clocks. Want to kill those GPUs quickly?
Does anybody try 2minners?
I have about 520mh on 4x3060 ti lhr, (2paliits and 2 TUF) . Whattomine said that I should mine about 0.78 ergo per day, but for yesterday I had 0,52 ergo. Does anybody have same problem?
LHR cards ⌠driving me bonkers. If you leave the fan on auto speed then when the cards get hot the hashrate drops because of increase in fan power. If you set the card to manual fan speed and it just get a bit hotter in the day then hash rate also drops.
. Mine runs at 135,8 then just drops to 82 when it climbs 2 degrees.
Suggestion is tune your cards when your room has reached its max temp
So I tuned it midday then when it gets cooler it climbs to 137 and holds there.
