Hello,
We are currently starting to run an ERGO node v4.0.16 using docker.
The max heap size of java is correctly set as the log tells upon startup:
Picked up _JAVA_OPTIONS: -Xmx3g
However what we experience at some point is:
- peaks of memory consumption reaching 3 GB with logs telling
java.lang.OutOfMemoryError - then later, no more
java.lang.OutOfMemoryErrorand the memory consumption goes up to 16 GB and even more
As a workaround, we have set a limit of memory consumption using docker itself.
But we would like to know if this is an identified problem, or if someone did experience that ?
At first glance Iβd say it looks like a memory leak, so we definitely cannot use it that way at the moment.
