In this article, a new method is presented in order to develop tools for Ergo on both mobile devices and desktop computers. Here, ordinary requirements for tool developments are briefly discussed.
The main goal is to be able to run the same code on different platforms. The idea has been implemented in a software stack. In this stack, at the first step of code development, the typescript programming language and React.ts library are used.
The common procedure for building a React typescript project is to use the following command:
create-react-app <app-name> --template typescript
Blockchain operations are performed using the sigma-rust package. The details can be observed in the following repository
https://github.com/ergoplatform/sigma-rust
The application created using create-react-app command does not support WebAssembly (Wasm). A basic solution is to eject the code and modify webpack configuration in order to support Wasm. However, this solution is not recommended, since the developer will have to manage the build process on his/her own. A preferred solution is to use react-app-rewired or craco.
One either has to install these libraries and apply the required settings to the project or use a template where the settings are already configured. We suggest using the following template to build the project In this stack, It is recommended to create the project using the following command:
create-react-app <app-name> --template ts-rewired
In order to connect to the blockchain, it is recommended to use erg-sdk-js library, which has good interfaces for communicating with explorer and also provides access to sigma-rust. Using the above-mentioned stack, any app that works on the blockchain can be easily run inside the browser.
On mobile devices running Android or iOS, it is recommended to use Capacitor package in order to create native applications based on the React codes.
Capacitor can be set up as follows:
npm i -s @capacitor/core
npx cap init
To add support for Android and iOS, run the following command:
npm i -s @capacitor/android
npx cap add android
npm i -s @capacitor/ios
npx cap add ios
One of the advantages of using capacitor is its active community which provides a wide range of tools for working with hardware.
For example, @capacitor-community/react-hooks, provides access to hardware in the same way available in react-hooks. In addition, in order to simplify the development procedure and standardize the capacitor build procedure, on desktop computers, an executable application based on React codes can be created using @capacitor-community/electron.
In order to connect to the database, it is recommended to use @capacitor-community/sqlite. There is a problem in code development using @capacitor-community/sqlite: this library is restricted to be used in the capacitor platform, which needs to be built before being executed on mobile or computer.
Since running each build usually takes about one minute, test and debugging processes may take a lot of time. In order to solve this problem and accelerate the development process, the application of sql.js library is proposed. This library is a Sqlite emulator, which in fact creates a sqlite database in RAM and also stores it on localStorage. The localStorage space is limited to 5 MB. This restriction is not a concern during development.
Finally, an object-relational mapping (ORM) is suggested to simplify the usage of the database. For this purpose, the application of typeorm is recommended. This library supports both the above-mentioned databases. The developer only needs to design a proper data model that fulfills the project requirements. Typeorm automatically updates the database during development. Moreover, It allows creating database migrations.
As an example of using this stack, minotaur-wallet is being developed based on it (ERGO HACK II participant). The first version is going to be released in a few weeks.
Credit for this article goes to ‘Esmail Mohammadi’ @vorujack
