Hello everyone, I’m new to this node and just downloaded it to one of my androids. My question is that the node is running , it says local host ,/ info online. I download the wallet to the phone and wanted to know how to add my address to node and is there anything else I have to do ? It says ### Headers 100% complete and then xxxxxx/xxxx , so I’m assuming it’s running.
Just to let you know that once I downloaded the node , it was running. I then let it run while I was downloading the wallet. So I added the wallet address to the node after I got it and the node started to run again! I possibly could of done everything correctly or possibly not. I just wanted to make sure I did it correctly or not and if I didn’t, if someone could help me? Also does this node run in the background of my phone if I have another app open?
Can you send me a step by step instructions on what you mean cauase I have a ton of miners and I’m not saying I’m a PRO but I know what I’m doing cause I don’t understand were to put seed phrase if that’s what you mean, I would appreciate that?
