This post outlines changes needed for reusing possibilities of Ergo’s contractual layer (Sigma), peer-to-peer and consensus-related functionalities (such as Autolykos) in different environments, such as:
- offchain contractual environments (such as offchain cash)
- merged-mined sidechains
- dedicated sigmachains (with trustless pegging)
Let’s consider what’s needed for these settings briefly before jumping on details:
SigmaState
For all the environments, modifications in contractual layer (Sigma repository) are needed. So makes sense to start with them. Changes in following entities would be needed, in most cases:
Header,PreHeadertypes (SHeader,SPreHeaderclasses) which are specific to Ergo blockchainBox(SBox) type which is a basic unit of storage on the Ergo blockchainMinerPubkeyandHeightAST nodessigma.Contextclass
along with projections into SigmaJS and compiler levels
It makes sense to tag all those context-dependent entities with a special (empty or almost empty) trait, to find them easily. Then create special packages in all the modules with context-dependent entities. Then document what and how to change in order to get programmable money for a new environment.
Ergo node
Ergo node modifications are not needed for offchain contractual environments, as such apps are not using blockchain.
For merged mining setting, likely, current node API would be enough just. A merge mining client connected to a mining node would use /mining/candidateWithTxs API method to include sidechain block data into mainchain transactions (as shown in https://github.com/ross-weir/ergohack-sidechain/blob/main/docs/whitepaper/sidechain.pdf, Section 2), along with existing methods to track blocks and transactions (e.g. ones available in /blocks). Merged mining client logic can be implemented using any technology stack then.
A dedicated sigmachain can be built in Rust or Scala. In case of Rust based sigma-chain reference client implementation, as currently only contractual layer is translated into Rust (sigma-rust framework), networking layer implementation would be needed, it can be adopted from existing Proof-of-Work (and not only) cryptocurrencies implementations done
in Rust. This could be a good option to start a Sigma-powered blockchain which is similar, in regards with consensus and/or block structure to ones having client implementation in Rust already.
Another option is Scala. Here it is possible, as with Rust, to just use Sigma (Scala implementation) and adopt consensus / block structure from some existing cryptocurrency with client done in Scala. But in most cases a dedicated Sigmachain implemented in Scala would derive from Ergo node code likely.
For modifying Ergo node code, especially considering ongoing possibly deep changes needed for sub-blocks implementation, we propose to proceed as follows:
- mark Proof-of-Work related functionalities (PoW function / mining API etc) and move them to special packages to make PoW function change easy. In most cases, a dedicated Sigmachain would touch PoW function just.
- explore what parts of other functionalities (block structure / predefined contracts / etc) are needed for dedicated Sigmachains, and plan further refactoring accordingly.
