For the protocol side. The ask, up front (details at the end): which native post-quantum verification, if any, would core accept as a soft-fork method, and is a measured table of this shape the evidence an EIP needs? Three things: the quantum-day vault, built and judged on a devnet (§1); a family of rotating-key receive addresses, two with hash-based keys (§2); and the cost of verifying FIPS 205 SLH-DSA-SHA2-128s in script today, the ask’s evidence (§3 and §4). §5 records the double-satisfaction forms the contracts use. The wallet half (KeepAlive and the two-step vault on mainnet, with a per-policy integration kit) is a companion post.
Where it came from: a keyless consolidation path with a per-box bounty was already on mainnet in the staking incentive boxes, 6,847 of them merged before rent age (skunks/upkeep/mainnet/README.md, via skunks/keepalive/README.md). That path is not exposed to the merge finding in §5: it requires exactly three outputs, the bounty and the fee at fixed values, so all other value stays at its script (explorer SHA-256 templates 278ccff2… and b924a4f7…, decompiled and run on the devnet, skunks/keepalive/staking-precedent/). KeepAlive generalises that for anything a holder wants kept, and the quantum-day vault was suggested in dev chat (a vault spendable by proveDlog until an oracle or miner signal declares quantum day, then only by a hash-based signature), built here on KeepAlive’s maintenance (skunks/qvault/README.md).
Everything is in https://github.com/cafebedouin/skunkyard: skunks/qvault/, skunks/policy/6-rekey/ (with SCHEME-SIZING.md and slhdsa/), and research/pq/ROADMAP.md (the 2026-10-10 update). Every accept or refuse row was judged by the devnet node or its wallet, except the SLH-DSA harness rows, which are marked “in the harness”; the SLH-DSA cost figures come from an interpreter harness, with two honest spends and seven forgeries then judged by the node, on the devnet’s cost parameters and again on mainnet’s. Six review rounds read the contracts before this post. The most serious defect they found, in the fifth round, is fixed: every keyless merge in this family accepted a successor funded from outside the merged boxes, so a third-party payout into such an address could be combined with draining it; every merge now admits no foreign input, which changed every template in the family (§5; run on the devnet for the KeepAlive address and the quantum-day vault, and the rotating members’ suites re-run against the fixed trees). Every other defect the reviews found is fixed and re-tested, except three, disclosed in §5: a Pending2 completion can strand funds at a destination that reads its own registers; and, found by reading in the sixth round and not run, the lone refreshes of the register KeepAlive vault and the inheritance vault admit foreign inputs, and the flag boxes have no size bound on refresh. The limits that are design costs (the schedule’s griefing, the shared flag box) are stated with each member. The verdict files cited below are published; the attack harnesses that produced the planted, weld, schedule (sched-, r3-), cross-vault, Vault2 (v-) and destination (c-, s-, w-) rows are not. What the reviews found, and how: posts/2026-10-policy-review-lessons.md.
Not for value yet, on either hash path. SLH-DSA: BouncyCastle signatures from two key pairs (thirteen from one, one from the other), a 1.86 snapshot build as the only oracle, one parameter set (128s, security category 1). WOTS+: a Blake2b instance checked only against our own signer. Nothing ships before FIPS 205 known-answer vectors through the Python reference and the script, a differential run against BouncyCastle over many keys and messages, a second implementation agreeing, and a security review of the script against the standard; for this WOTS+ instance, which no standard specifies (RFC 8391 and FIPS 205 define WOTS+ only as a component, with SHA-2 or SHAKE), a written specification of the instance and a second implementation against it (research/pq/ROADMAP.md). No wallet signs either, and key derivation from an EIP-3 seed is unspecified.
1. The quantum-day vault (devnet, 39 of 39; not for value yet)
A receive address whose secp key spends only while a flag box, read as a data input and found by a singleton NFT, says false, and before a per-owner backstop height. After that, only a hash-based key spends. KeepAlive’s keyless merge and refresh are kept, since they use no key, so the box outlives storage rent (skunks/qvault/QVault.es, 1,261 bytes for the test vault with the near backstop and 1,262 for the three with far ones, at devnet constants, with the no-foreign-input merge of §5, devnet-results.json vaults; QDay.es, 148 bytes; skunks/qvault/devnet-results.json, 39 of 39). The flag is fired by an oracle key and never reset (rows 11 to 13); leaving it out, or showing a look-alike, closes the secp path rather than opening it (rows 2, 3 and 16; a fired flag closes it too, row 15). The secp key is a script constant, so it is public in the address itself: the backstop height is the guarantee, the flag an early warning. Firing cannot steal: a stolen oracle key can only close every vault’s secp path early. It can strand owners, since after firing only the hash key spends, and today no wallet signs WOTS+ or derives its key from the seed.
The hash key is WOTS+, sign-once: the vault signs once, to migrate, so a one-time scheme suffices for the boxes merged before that spend. Every chain hash is keyed by a per-vault public seed and the (chain, step) address, so two vaults share no hash target as long as each has its own seed (the wallet must choose a fresh seed per vault) (skunks/policy/6-rekey/WotsPlus.es, 717-byte tree). The instance is Blake2b-256 with a 2-byte address in the FIPS 205 style (a simple tweakable hash keyed by a public seed and an address), so no standard’s exact instance; RFC 8391’s WOTS+ instead derives a key and a bitmask for each step from the seed and address. Five negatives refused by the node on WotsPlus.es, whose chain the vault uses unchanged, and on the vault itself: a byte flipped deep in the signature, bytes appended, a truncated signature, another key’s signature on the same digest, and a valid signature replayed on a second box (skunks/policy/6-rekey/results-wotsplus.json, wp-*; the vault’s rows 6a to 6e). The tweak costs about 18% over plain WOTS on the script cost (17.6% at 480 hashed steps, where each scheme has two measured spends; the fit’s 18 to 19% at a random message’s mean of 506 extrapolates plain WOTS beyond its measured 435 to 495 steps, and that fit is flat within its noise; eight spends per scheme, script cost as node cost less the devnet’s fixed 12,100; 6-rekey/results-wotsplus-fit.json), against an 8% estimate: interpreter operations that run at every chain position, hashed or not, dominate (the fit’s slope is about 11 per hashed step against a node-cost intercept of 45,269, 33,169 on script cost).
What the contract does not do: it checks the flag box by its NFT’s id, not its script or the NFT’s amount, so a second unit of the NFT, or a unit minted into a key address, opens the owner path (rows 8c, 8d: the vault cannot tell; the wallet checks the mint); the flag box is shared by every vault, and one oracle key closes every vault’s secp path. A refresh changes the flag box’s id and voids an owner spend built against the old box (rows 7a to 7c), so QDay.es now refreshes only in a KeepAlive-style window, about once per period (at most once per PERIOD − WINDOW − SLACK blocks; row 7d refused; the old contract allowed a refresh every block, rows 7e, 7e2). Who holds the oracle key, or whether a miner signal replaces it, is the governance question. A vault with several boxes must merge them keylessly before the one hash-key spend, since every box shares the commitment (mine.size == 1 stops two boxes in one transaction, not a second transaction later; the merge fee comes from the bounty since §5’s fix, so boxes worth less than the fee wait for more payments or a miner’s own block, by reading); after quantum day or the backstop, a payment that reaches the address after the hash-key spend can still be merged keylessly (m2) but withdrawn only by a second signature with the spent one-time key (m3; the secp key is refused, m1), and two signatures under one WOTS+ key may let anyone who sees both grind a forgery for any later box at the address (§2), so the wallet stops giving out the address before it migrates.
2. A receive address whose key rotates: three members, not one winner (devnet; hash keys not for value yet)
The first rekey account (RekeyAccount.es) kept its keys in registers and called a box “registered” if R4 and R5 existed. Review found that anyone could plant such a box at the victim’s address with their own keys and have the keyless merge pull the victim’s plain payments into it (skunks/policy/6-rekey/results-planted.json, old-1 and old-2: custody taken, then cashed out). That started a design program (6-rekey/CHARTER.md), whose answer is a family: each member is for a different requirement.
| member | contract | tree | rotate | plain payment | token | from seed | hash key |
| fixed key | FixedKey.es (a P2PK) |
36 B | move every box: 12,503 for one, 14,906 / 19,712 / 29,324 for 2 / 4 / 8 (results-fixedkey-n.json) |
free, as at any address | no | yes | none |
| welded NFT account | RekeyAccount3.es |
1,378 B | in place: 13,115 (secp key), 51,240 and 51,460 (two successive WOTS+ hash-key rekeys, results-weld.json) |
keyless merge, 15,685 (2 inputs) | yes | no (found by its NFT) | WOTS+, per-key seed |
| key schedule | RekeySchedule.es |
1,546 B | in place: 55,770 (WOTS+ leaf, results-schedule.json sched-fwd) |
keyless merge, 14,924 / 19,806 / 30,466 at 2 / 4 / 8 inputs (results-schedule-r3.json) |
no | yes, by design | WOTS+ leaves |
All results files are in skunks/policy/6-rekey/; devnet mempool figures with inputCost 2,000, mainnet charges 2,407. Tree sizes and costs are for the trees with the no-foreign-input merge of §5, re-run after it (weld 22 of 22, schedule 11 of 11 and 18 of 18); the hash-key rekey costs moved by up to about 500 against the previous run (6-rekey/README.md keeps both), since the hashed steps depend on the signed message. A payment carrying a register of a type the member does not expect is lost, since a typed register read throws rather than reading as absent (sigma-state InvalidType): an EIP-4-style Coll[Byte] memo in R4 at the NFT account, which the owner alone cannot spend either (skunks/policy/2-twostep/results-destinations.json, w-memo-ra3, w-memo-ra3-alone), and a GroupElement R4 at the key schedule (w-ge-sched, w-ge-sched-alone), while an R4-only Coll[Byte] box at the schedule merges (s-sched-R4). These destination and memo rows ran on the trees before the fix; the fix adds one clause to the merge and leaves the register reads as they were (by reading). Wallets send register-free payments.
- Fixed key: a personal receive address that rotates seldom. Cheapest to receive and to rotate; rotation changes the address.
- Welded NFT account: identity as a transferable object. The account is an NFT the wallet mints with amount one that never leaves the script: every output at the script must carry it and the registers, no output off the script may carry it, and closing the account burns it, so a transfer is a rekey and nothing else (
results-weld.json, 22 of 22: four rows, v2-brick, v2-brick-sp, v2-peel and v2-peel-cap, reproduce the previous version’s two edges; on this version v3-brick, v3-peel and v3-plant are refused and v3-xfer and v3-close accepted). The costs are a mint, an address not derivable from the seed, and token-aware wallets; the contract does not check the NFT’s supply, so the wallet mints it (amount 1) in the transaction that creates the first registered box, and merges every plain payment before closing. Found by review, fixed: the first weld checked only that a successor carried the NFT, not the registers, so a rekey whose successor omitted R4 or R5 was accepted and left a box no path could spend; now refused (v3-no-regs, v3-no-r5). Found in round three, fixed: the hash key’s tweak was the NFT id and the (chain, step) address, with no key counter, so every key the account installed over its life shared one hash family; R5 now carries a per-key public seed beside the commitment, the seed is in the tweak, and a hash-key spend may not leave a successor under the spent key’s seed (the contract remembers only that one, and the owner path checks no seed, so the wallet never reuses a seed; v3-hk-sameseed and v3-hk-wrongseed refused; two successive rekeys v3-hashkey, v3-hashkey2 accepted). Its own negatives, append, truncate and a deep flip, are refused (v3-hk-append, v3-hk-truncate, v3-hk-deepflip). - Key schedule: a stable published address with no token, derivable from the seed by design (the derivation from an EIP-3 seed is not specified yet). The address embeds a Merkle root over N seed-derived one-time commitments (N = 8, fixed in the contract; a larger tree needs a new contract); a box is registered only if its leaf proves into the root, and each rekey reveals a later leaf with a one-time signature at the current one (
results-schedule.json, 11 of 11: sched-foreign, sched-fwd, sched-back). An XMSS shape, not an SP 800-208 instance. Found by review, fixed: an unchecked index (8 took leaf 0’s Merkle path; now refused, sched-idx8 and sched-idx7to8), no close path (now a leaf-signed spend with no successor, sched-close, which still reads context variable 0; merge every plain payment first, as for the NFT account), and one seed for all leaves (the leaf index is now in the tweak, as FIPS 205’s key-pair address separates key pairs; that separation is checked by reading, since no run can show it; a cross-leaf row, a leaf-5 signature on a leaf-1 box, is refused and tests only that the signature is checked against the box’s own leaf,results-schedule-r3.jsonr3-cross). The schedule’s own append, truncate and deep-flip rows are refused (r3-append, r3-truncate, r3-deepflip). The script verifies the successor’s leaf and leaves the other outputs unconstrained in amount; the rekey signature covers them all. Its price is a griefing, measured and stated. A griefer’s merge must keep the registered input’s own key, so the theft we tried was refused (sched-grief-theft). But a griefer can plant a box at a past leaf whose Merkle proof has appeared on chain and merge the account’s plain payments into it (sched-grief, accepted) or at the current leaf from the block that installs it, since the installing rekey carries its proof in a context variable (r3-plant, accepted; the owner can neither fold the planted box into its own rekey nor merge it with its own box, r3-fold-rekey and r3-fold-merge refused), and the owner can reclaim that payment only by signing a second time with that leaf’s spent one-time key (sched-recover; at the current leaf two signatures, r3-reclaim-1 and r3-reclaim-2, both accepted). Two WOTS+ signatures on different messages let anyone who sees both grind for a forgery at that leaf (possibly at practical cost; not computed here: treat a leaf that has signed twice as broken), each further reclaim there makes it cheaper, and each forged spend needs its own grind, since the message includes the box id; a forgery there spends any box registered at that leaf, the owner’s own box until it moves off it and every later box a griefer plants and fills with the owner’s payments (reasoned from the contract, not run). So the owner chooses between a lost payment and opening that leaf to theft. With a many-time scheme, signing again under a past key costs no security (only the spend’s fee), so the griefing shrinks to a nuisance; that is why SLH-DSA is the planned default for this member. The rotating SLH-DSA contract is not built, only the verifier.
Both in-place members reuse KeepAlive’s merge. Like for like, a merge costs about what a fixed-key move of the same size costs (two inputs: 14,924 and 15,685 against a two-box move at 14,906; eight: 30,466 against 29,324), so the in-place members’ extra cost is one such transaction per batch of payments, plus 51,240 to 56,720 per hash-key rekey against 12,503 for a one-box move; what that buys is an address that does not change on rotation.
3. An SLH-DSA-SHA2-128s verifier fits in a proposition today (not for value yet)
skunks/policy/6-rekey/slhdsa/SlhDsa.es implements FIPS 205 Algorithms 20 and 24 for SHA2-128s (by our reading against the standard and BouncyCastle’s acceptance; the gate at the top still applies) and compiles to a 1,516-byte tree (cap 4,096). The message is pure SLH-DSA with an empty context over the spend digest blake2b256(SELF.id ++ the outputs' bytes), not HashSLH-DSA (no row yet tests a signature over a non-empty context, a HashSLH-DSA signature or one from the internal function without the prefix: not run). In the interpreter harness: script cost 188,247 on the spend the negatives mutate (eight random spends: 185,784 to 189,443, median 187,566; slhdsa/run.log), 201,250 once mainnet’s fixed 13,003 per-transaction charge for one input and two outputs is added (computed), and 201,816 measured on a devnet voting mainnet’s cost parameters (slhdsa/results-devnet-mainnetcost.json, 9 of 9, the honest spend mined at 8,054 bytes); a 7,856-byte signature in context variable 1. BouncyCastle’s signature is accepted. Refused, in the harness and then by the devnet node: bytes appended, a truncated signature, another key’s signature on the same digest, a byte flipped in a FORS authentication node, a byte flipped in a layer-6 WOTS+ chain element, a signature made for other outputs, and a valid signature replayed on a second box at the same address (slhdsa/results-devnet.json, 9 of 9: two honest spends and seven forgeries; the honest spend mined at cost 201,416 and 8,054 bytes, transaction fa6d2aed…). Found by review, fixed: the first build had no signature-length check, so a valid signature with bytes appended verified; the guard-less tree still accepts it in the harness (the control), and every hash verifier presented in these posts now checks the length (FIPS 205 Algorithm 20, line 1; run on all five: this verifier, WotsPlus.es, the vault (6a, 6b), the welded account (v3-hk-append, v3-hk-truncate) and the schedule (r3-append, r3-truncate)). Computed, not run: about 39 such spends per mainnet block by cost (8,001,091 / 201,816 = 39.6); about 4.0× the WOTS+ spend on the same devnet (201,416 against 50,273 node cost, both mined on that devnet’s parameters; 4.9× on script cost, the harness’s 188,247 against 38,073, node cost less 12,200). No valid signature reaches every chain at 15 steps: the checksum caps a layer at 510 of 525 steps, and each layer’s digits come from a hash. The eight spends took 1,785 to 1,920 steps; a measurement-only variant that hashes all 3,675 steps costs 248,050 script (261,053 node), an upper bound, and interpolating between the valid spend and that variant puts a valid signature’s 3,570-step cap at about 244,600 script, an estimate (the eight-spend linear fit says 233,600, about 5% under the variant; slhdsa/README.md).
4. Interpretation is the cost, and the ask
Hashing is about 11% of the script cost of a random SLH-DSA spend (computed from the interpreter’s per-call charge over the reference’s 2,038 to 2,173 tweakable hash calls plus H_msg’s two, slhdsa/run.log), rising to about 15% at the all-steps bound, where a like-for-like substitution measures the same share; the other 85 to 89% is the interpreter’s per-operation charges. For plain WOTS the share is 6.9%, measured in the interpreter harness at the worst-case message (q2/RESULT.md), and the same per-call formula reproduces that figure, so changing the parameter set or the hash would not change the split much. A native verification was sized at about 1,900 to 1,960 cost units by a benchmark on one machine, one JVM and a BouncyCastle snapshot, reproduced within 4% on the 6.0.7 jar (research/lattice/RESULT.md; 14,909 to 14,967 per transaction with the fixed charge), against 188,813 in script on mainnet cost parameters (201,816 less the 13,003 fixed charge): about 100× per verification, 13.5× per transaction, computed from an estimate. That is the one lever that needs a soft fork: a new verification method behind a new ErgoTree version, as 6.0’s methods were added (research/policy/evidence/ergo-capabilities.md, §8). The same benchmark sizes a Falcon-512 opcode at about 13,095 per transaction with a 656-byte signature as BouncyCastle encodes it (666 by the specification).
The ask. The table says hash-based signatures already work in script at about 200,000 per spend (201,816 measured on mainnet cost parameters): about 15× a P2PK spend (13,406), about 39 per mainnet block by cost against about 596 (q2/RESULT.md; 600 on the benchmark’s own baseline). A native SLH-DSA method would cut the per-transaction cost about 13.5× by a one-machine benchmark estimate, but block capacity only about 4×, to about 158, because the 7,856-byte signature then makes the spend size-bound; a Falcon-512 opcode would be bound by the fixed charge at about 611 per block (research/lattice/RESULT.md). The cost constant for any of these would need core’s calibration, not our benchmark. Before anyone drafts an EIP: which would core accept as a soft-fork verification method, SLH-DSA (hash assumptions only, the same scheme the script path uses), a lattice scheme, or a generic tweakable-hash-chain primitive, which might remove much of the interpretation overhead for every hash-based scheme (not sized)? And is a measured table of this shape what an EIP needs?
5. The double-satisfaction rule these contracts follow, and the two cases the usual guard missed
This is Ergo’s known double-satisfaction rule; what these contracts add is three forms of it and two cases where the usual guard fails. An output that a keyless or output-checking path relies on must answer for exactly one input, or hold the totals of every input relying on it:
- the box is the only input of its script in the transaction (the vault’s announce, which also pins R6 to its own script; the old pending box; a hash-key spend, whose outputs may sit anywhere and which is safe because the signed message includes the box’s own id, as the replay rows test);
- every input of the script names one output that holds their totals, and no input of any other script is in the transaction (the KeepAlive address’s merge and lone refresh; the quantum-day vault’s maintenance; the rotating addresses’ merge, which also requires exactly one registered input; the second clause is the fix described below);
- the output carries the input’s id (the lone refresh of the register KeepAlive vault
KeepAlive.esand of the inheritance vaultskunks/policy/4-inherit/, R5 or R6 = the spent id; the rotating addresses’ merge, R6;Pending2’s completion and cancel, R4).
The flag boxes (the quantum-day flag, the canary) use none of these: the singleton NFT they carry binds their output, given a supply the contract does not check (rows 8a to 8d); the canary still refreshes every block, as QDay.es did before row 7d. Neither flag contract bounds the successor’s size on refresh, unlike KeepAlive, so a refresher could pad the flag box and raise its storage rent, and a collected flag box closes every vault’s secp path (found by reading in the sixth round, not run; QDay.es only within its window). A path guarded by a key alone needs none of this. A path that pairs a key with a check that some output exists, or that a named output holds a value, does, when that check exists to restrain the key’s holder: the announce against a stolen owner key, the cancel against the recovery holder (and the owner, whom the same guard binds). A check that every output satisfies a property (the welded account’s custody, the inheritance owner path’s height stamp) cannot be double-satisfied and needs none of this. Forms 1 and 2 count per script, which is safe only when the relied-on output must sit at that same script (the merges, the lone refresh) or is pinned back to it (the announce’s R6), and only when no input of another script can rely on the same output (the second case, below). The old pending box paid out to R4, a different script, and that is the hole Pending2 closed with form 3. The price of form 3 here: Pending2 writes the spent box’s id into the destination output’s R4, and the completer chooses every other register, so a completion into a script that reads its own registers strands the funds: into the key schedule with R5 set the landed box has the schedule’s shape and no leaf, into the register KeepAlive vault, inheritance and the welded account the typed read throws; into the KeepAlive address or the quantum-day vault it is spendable, and into a key address by reading, since a key script ignores registers (skunks/policy/2-twostep/results-destinations.json, run on the pre-fix trees). The robust shape, decided and not built, carries the id in a separate receipt output; until then a Pending2 destination is a plain key address.
Counting per script is also unsafe when an input of another script can rely on the same output, and that is a property of the merge, not of the pending box: the merges as first built (the KeepAlive address’s, the quantum-day vault’s, both rotating members’) accepted any successor at their script worth at least the merged total less the bounty, without checking that the successor was funded by the merged boxes. Any payout into such an address that a third party executes (a completion of either pending box, a settlement, an order fill) pins value there and could satisfy the merge too, so the executor let the payout stand in for the successor and took the merged value less the fee. Found by reading in the fifth round; on the devnet the node accepted it against the pre-fix KeepAlive address and the pre-fix quantum-day vault (skunks/keepalive/results-shared-output.json, 1-kaa-pre, 1sub-kaa-pre, 2-qv-pre), and with the payout carrying the merged boxes’ token in at least their amount (1c-kaa-pre): a token protects a box only when the payout cannot carry it (1b-kaa-pre, refused). A plain payer cannot profit, since they fund the payout themselves and the merge bounds their take by the bounty. The first fix proposed, a bound on the successor’s value, does not close it: the executor chooses which boxes to merge, and with a value bound alone the node accepted the theft at a payout of the total, the total less the bounty and halfway between, the executor taking the merged value less the fee each time (results-shared-output-boundary.json: the value-only variant accepted all three, the full fix refused the same three). No value-only check can work, since the script cannot see which input funds which output. The fix is the second clause of form 2: every input of the transaction at this script, so the only value in the transaction is the merged boxes’ own and the bounty is all that can leave, with the value bound kept as defence in depth. Against the fixed trees every theft row is refused, the plain keeper merge accepted and the sponsored merge refused (14 of 14): the price is the sponsored merge, so the fee always comes from the bounty, as the keyless mainnet merge and the keeper job already did. A second price, by reading and not run: where a plain payment has no key path, at both rotating members (their key paths require a registered box) and at the quantum-day vault after quantum day, a payment whose bounty cannot cover the fee can no longer be merged on someone else’s fee; it waits for more payments, at the vault the one hash-key spend leaves it behind for a second signature, and one left when a rotating account closes is stranded. The clause is in all four merges; on the rotating members the theft was not run, since their merge successor must already carry the account’s own registers, which refuses a Pending2 completion as a successor by reading, and the clause closes any payout that could carry them; their suites pass unchanged against the fixed trees (§2). The KeepAlive mainnet demo ran the pre-fix tree; the fixed tree has since run on mainnet: a deposit, a plain payment, a keyless merge and an owner spend signed by ergo-lib (companion post). The general rule: a keyless merge that checks only “at least the total less the bounty” is exposed when the merged boxes are plain value and the transaction may carry other value; it is closed by admitting no foreign input, or by pinning every other output’s value, and boxes whose tokens a payout cannot carry are protected by the tokens alone. With the fix, a KeepAlive address can receive keyless-executed payouts as far as the merge goes; a Pending2 completion into it still lands with the pending id in R4, which the address ignores, and the destination rule stays a plain key address until the receipt shape is built (companion post, §2).
Form 3 has the same gap, found by reading in the sixth round and not run: an id binding makes the output answer for one box of its script, not that the box funded it. The lone refreshes of KeepAlive.es and of the inheritance vault admit foreign inputs, so a payout into them whose executor may set the id register could stand in for the successor of a token-free box in its refresh window (their exact-token rule protects any box with tokens; a Pending2 completion cannot do it, since it writes its own id into R4). Neither contract is offered as a receive address, and the same clause would close it.
Pending2 is tested with real vaults (Vault2.tree, 338 bytes, the same template as the old vault’s; results-vault2.json, 21 of 21); the mainnet demo vault runs the old pending tree. The rule does not cover a forged input state: the first rekey account kept one registered input per merge and still lost custody to a planted box (results-planted.json old-1, old-2), because “registered” could be forged; the fix was registration that cannot be forged, a welded NFT or a Merkle proof into the root. Nor does it cover a forged data input: the vault trusts the flag box by its NFT alone, so the flag’s singleton supply and its mint into QDay.es are deployment facts the contract does not check. The rows (skunks/policy/2-twostep/results.json, results-crossvault.json and results-vault2.json, skunks/keepalive/devnet-results.json, address-results.json, results-shared-output.json and results-shared-output-boundary.json, skunks/policy/6-rekey/results.json):
- two vault boxes announced into one pending box (two-step row 2b, refused; accepted by a vault built without the guard,
results-vault2.json2b-ng); - two pending boxes cancelled, one output to the vault and one to a stranger (row 16 refused; accepted without the guard, row 17);
- two pending boxes completed with one output to a stranger (row 12 refused; accepted without the guard, row 14). The old guard’s cost: honest batching refused too (row 13; accepted without the guard, row 15);
- two pending boxes of different vaults completed into one output: accepted against the old pending box (form 1 counts per script, row old-1), refused against
Pending2(form 3, row new-1; with real vaults v-10, and the cancel side across two vaults and within one, v-7c and v-7d); - two identical register KeepAlive vaults refreshed into one output (
keepalive/devnet-results.jsoncase 9, refused by the id binding); - for form 2: two KeepAlive-address payments split into two outputs (
address-results.jsoncase 6, refused: an enforcement row, not a theft); and the one-registered-input rule, a merge of two registered boxes of the pre-NFT rekey account (6-rekey/results.jsonrow 13d, refused); - for form 2’s second clause: a third-party payout standing in for the merge successor (
results-shared-output.json: accepted against the pre-fix KeepAlive address and quantum-day vault, 1-kaa-pre, 1sub-kaa-pre, 1c-kaa-pre and 2-qv-pre; refused against the fixed trees, 1-kaa-post, 1sub-kaa-post, 1c-kaa-post, 2-qv-post; accepted against a value bound alone,results-shared-output-boundary.json).
Parked, for the record: ring payments from a shared pool (skunks/policy/7-cheque-bank/, a 1-of-N atLeast over deposit commitments, capped at 255 members) and miner-signalled flags (skunks/policy/3-extension/, a key proven in any of the last 9 headers’ extensions; a stock miner cannot write a custom key, a patched 6.0.7 node did, and a stock peer accepted its blocks). Objections welcome.
