I have restarted the node several times. Deleted all the folders and resynced. It actually 100% completes sync on headers then gets stuck at a random height every time. Tried different versions of Jar file. I had a fully synced node awhile ago but took a break from mining so it all used to work. Not sure what I’m doing wrong now. Using the latest Java JDK.
Hello! I recommend asking this question on the Discord server, here: Discord
Please try to sync with mining = false and then turn mining on
I am both frustrated and happy that it was that easy… argh. I tried so many things but that. Thanks so much for the help Kushti. Looks like everything is syncing properly and wallet shows the correct total now.
